parking brake adjustment - Kia Forum
post #1 of 13 (permalink) Old 11-15-2010, 09:37 AM Thread Starter
Drives: 2007 Rondo
2007 rondo with 35K miles... parking brake very soft and goes to the floor before engaging fully... Already adjusted the brake shoes to be as tight as I dare but the cable feels slack... I would say the adjustment should be at the pedal... but cannot get to it under the dash... anybody know an easy way to take up the slack without total dismantle?....
jimn25 is offline
post #2 of 13 (permalink) Old 11-15-2010, 09:46 AM
PLP
PLP's Avatar
Quoted: 306 Post(s)
look into KGIS, there is a very nice section discussing parking brake adjustment, also how to play with the pedal
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #3 of 13 (permalink) Old 11-18-2010, 04:00 PM
Drives: 04 Mercedes C230, 08 Rondo LX V6
Quoted: 5 Post(s)
Wheel off, rubber plug out. I cannot see or find the adjusting wheel. Do some Rondos just rely on adjusting the cable?
forcejb is offline
post #4 of 13 (permalink) Old 11-19-2010, 06:06 AM
Supacabby's Avatar
Drives: 2014 Kia Soul, 1.6hdi auto, in Mixx trim, White over Powder Blue
Gallery: 9
Quoted: 3 Post(s)
I can only "presume" the Carens is no different to the Rondo, to adjust the rears properly on mine I took the discs off & cleaned out all the muck then readjusted as you would any other brake shoes. The only prob is the rear cross member gets in the way so you have to undo the 2 bolts that hold that & drop it out the way, total time of appx 1/2hour.
Owned 5 Carens as cabs, 3 x Mk2's & 2 x Mk3's & a Kia Magentis 2.0, all diesel & all worked hard for their living! Now got a 2014 Soul 1.6hdi auto in Mixx trim.
Supacabby is offline
post #5 of 13 (permalink) Old 11-19-2010, 06:08 AM
Supacabby's Avatar
Gallery: 9
Quoted: 3 Post(s)
PS to above: I noticed a slight lip on the drums so removed this with a good bit of elbow grease & some coarse paper, this just ensured it was easier to refit the drums over the newly adjusted shoes.
post #6 of 13 (permalink) Old 11-20-2010, 12:56 AM
Quoted: 5 Post(s)
The manual shows adjusting a star wheel with the rubber plug removed from the drum. The manual says nothing about having to remove anything else. When I removed the plug, I could not see ANY sign of that aforementioned adjusting wheel. So I just tightened the cable to get a 3.5" travel.
forcejb is offline
post #7 of 13 (permalink) Old 11-21-2010, 11:54 PM
Drives: '12 Soul + '12 Soul ! '12 VStar 1300T
Very simple/effective double nut adjuster at pedal. I FINALLY did mine at around 90,000 miles. It was weak from day 1. A little tough on the ol' neck getting in the right position to see/adjust,but not too bad.
GMmon is offline
post #8 of 13 (permalink) Old 11-30-2010, 07:38 PM
Drives: Sorento SX-V6 AWD
Quoted: 26 Post(s)
Put the trans in park, block the front wheels. Lift rear wheels off the ground. Make sure parking brake is off. Take wheels off, pull rubber plug. Rotate disc till plug/opening is at the very bottom. Use a slightly hook-shaped tool (I used a bent screwdriver) to engage star wheel. Lever up or down as the case may be to rotate the star wheel to expand the parking brake shoes. Make an adjustment, rotate the disc, make another adjustment. I did mine till they dragged, then back the other way three or so clicks so they just oh-so-barely dragged at one spot in the rotation. I figured that they'd wear themselves in pretty fast that way. Reinstall the rubber plug, reinstall wheels. Done. Oh, to ensure total contact I also put the parking brake on and drove forward a couple hundred feet, then took it off and called it done.
whodat90 is offline
post #9 of 13 (permalink) Old 12-01-2010, 12:40 AM
Quoted: 5 Post(s)
So you can't actually see the star wheel thru the plug opening?
forcejb is offline
post #10 of 13 (permalink) Old 12-01-2010, 06:35 AM
Quoted: 26 Post(s)
if you look through the hole when it's at the bottom with a flashlight you should be able to see it, but the hole really isn't big enough for observation. It's much better (for me anyhow) to go by feel.
whodat90 is offline
