How to adjust door alignment - Kia Forum
post #1 of 9 (permalink) Old 02-23-2010, 01:14 AM Thread Starter
Drives: Carens 2006 (2.0L 4 Cylinder A/T gasoline Engine)
Wind noise start annoying me on freeway/highway. So yesterday i inspect the possible cause, all weather-strips are seems ok, I just noticed that the driver side door is slight uneven from the back door (door align to it). Anyone here know how to adjust the door?
carens06 is offline
post #2 of 9 (permalink) Old 02-23-2010, 02:55 AM Thread Starter
i'm thinking if the striker plate (attached) can be adjusted (up down and left right) so that the door is shut tight.
carens06 is offline
post #3 of 9 (permalink) Old 02-23-2010, 02:35 PM
Memorial Super Moderator
pulsar86's Avatar
If you want to adjust the striker plate it is a good idea to mark around the plate at your starting position as once loosened the plate can move in all directions, and it gives you a reference point if you have to start over. Don't loosen the plate too much , just enough to move it's position inwards slightly. If you are not confident doing it yourself most panel shops will do it fairly cheaply for you, it doesn't take them long.
pulsar86 is offline
post #4 of 9 (permalink) Old 02-23-2010, 10:19 PM Thread Starter
good to know that the plate has a clearance to move, coz some cars ford taurus for example (my recent car) dont have this clerance. i'll try later today. thanks.
carens06 is offline
post #5 of 9 (permalink) Old 02-27-2010, 11:09 PM Thread Starter
The plate screw was stock Im having hard time loosened it. I just bought a long screw driver and spray WD40 many times but still no luck. It there a special tool I can use to move this thing?
carens06 is offline
post #6 of 9 (permalink) Old 02-28-2010, 01:22 PM
pulsar86's Avatar
I usually use a square shank large phillips screw driver that I can fit a spanner[ wrench ]onto to help loosen the screws. If you can't get a square shank screw driver, they are hard to get at times, you could do as I used to do and weld a nut to a round shank one. You sometimes have to lean your hip against the end of the driver to hold the head on the screw as you turn the wrench, so be careful. Another method is to fit a screw driver bit into a socket and use that. I wouldn't use an impact driver incase the paint gets damaged. The problem you are having is one of the reasons that sometimes it is better to have a panel shop do the job.
pulsar86 is offline
post #7 of 9 (permalink) Old 02-28-2010, 04:43 PM
Drives: 2008 Rondo EX, V6, 7 pass.
Try using an impact driver. This is a screwdriver type tool that you wack on the back end with a hammer while putting a torque on it in the direction you want to turn. THIS IS NOT AN IMPACT WRENCH. Very popular tool with motorcycle mechanics. The hammer hit seats the screw bit tightly into the screw, and the tool provides a quick snap to loosen the screw. I bought mine years ago, have used it for many things. Pulsar86 makes a good point- be careful you don't slip and damage the paint. The trick is to be straight on, take your time. My motto is- Do it correctly, do it once. Honest, Pulsar, I didn't steal it from you. My old man was a class A machinist, he drummed that into me at an early age.
oldfordman is offline
post #8 of 9 (permalink) Old 03-05-2010, 12:44 PM
base11's Avatar
Drives: 2009 Rondo EX 4 cyl
Yes and let us know if the adjustment fixes your window noise, a few of us are still living with this pain.
base11 is offline
post #9 of 9 (permalink) Old 12-04-2015, 06:35 PM
Tony Tsui's Avatar
Drives: 2014 Kia Sportage EX AWD
Quoted: 19 Post(s)
I got a rattle coming from my front passenger door and I highly think that moving the striker plate inward would get rid of it. It is a 2014 Kia Sportage. I loosened the 2 bolts on the striker plate(the size is T40 torx), but it would not move at all. I loosened them to the point where the bolts were sticking out a few millimeters and hit it with a hammer but it still wouldn't move. I was afraid to take them all the way out because I read that there is a plate inside the door jamb that the bolts screw into to be tightened. If you took the bolts all the way out, the plate will fall down inside. When the bolts were loosened, I pushed them in with my fingers and they went in and out as if there was a spring inside. Anybody know whats up?
Tony Tsui is offline
