How to rotate tires and reset TPMS? - Kia Forum
post #1 of 9 (permalink) Old 10-07-2009, 09:10 AM Thread Starter
Drives: 2008 Rondo EX 2.4
I searched the forum and could not find the answer.
I generally rotate my tires at home for free. The 08 Rondo EX we have has a TPMS. If I rotate the tires at home do I have to reset the TPMS and how would I reset it? Thanks all
Zuke is offline
post #2 of 9 (permalink) Old 10-07-2009, 02:25 PM
larrytbm's Avatar
Drives: 03 GMC 2500HD D/A, 08 Rondo EX V6
I rotated the tires a few weeks ago and didn't do anything with the TPMS. As far as I know, it only warns of low pressure, but not which tire position, so moving the tires is not an issue. But I could be wrong. The manual should have some info as well.
larrytbm is offline
post #3 of 9 (permalink) Old 10-07-2009, 05:26 PM
PLP
PLP's Avatar
Quoted: 294 Post(s)
I confirm that.
Rotation will not do anything to TPMS. This system will warn you if pressure drops below 20 PSI (+/- 3 PSI).
Rotation will not do anything with that. Moreover, even if you loose pressure, and bring it back again - it still will be fine.
USA - paid, repair manual
Europe - paid, repair manual
PLP is online now
post #4 of 9 (permalink) Old 10-07-2009, 11:43 PM
I agree. Rotating your tires will not affect the TPMS.
However, the TPMS more than likely knows where each tire is mounted. When there's a TPMS error, say sensor malfunction. The TPMS will tell the factory scan tool which tire it is according to 1,2,3, or 4. Depending on the manufacturer, the number one tire can either front left or right, or even back left or right. The service manual will tell which tire is where. That info is needed when the sensors have to be manually reset and programmed. Hence the funky TPMS reset tool that every tire shop and dealer now has.
On some new cars, resetting the sensors are done by taking a short trip above 15mph or so. Every vehicle model and manufacturer has it's own thing at times because of the introduction of revisions to the sensors.
pnx-r is offline
post #5 of 9 (permalink) Old 10-07-2009, 11:54 PM
kiaracer's Avatar
Quoted: 8 Post(s)
TPMS is not affected by tire rotations. as long as the sensor id numbers are still in the system, the system will recognize that the tires have been rotated automatically.
kiaracer is offline
post #6 of 9 (permalink) Old 10-08-2009, 09:28 AM Thread Starter
Sweet thanks all.
Zuke is offline
post #7 of 9 (permalink) Old 10-15-2009, 09:22 PM
Drives: Sorento SX-V6 AWD
Quoted: 26 Post(s)
I am currently intimately familiar with the TPMS on the rondo and can shed some actual knowledge. I just had my TPMS controller replaced under warranty due to constant illumination of the TPMS light when driving. Quick system description; each wheel has a sensor/transmitter that sends info about both pressure and temperature wirelessly to the receiver which is in the center console of the dash. It listens to all 4 transmitters and reports status. It receives actual data as to temp/pressure, but only displays the TPMS light if there's any (and I do mean any) problem with the system, and the tire light if there's a low pressure/high temp condition. Each sensor is told what position it's in, and then the controller is told which transmitter is in which position. Once again, however, the data is irrelevent to the system. As long as it receives all 4 signals you can rotate the tires wherever you want. If you have a problem with the system, however, they'll need to retrain it for troubleshooting purposes.
whodat90 is offline
post #8 of 9 (permalink) Old 01-13-2011, 05:25 AM
Hi. I'm new here. I really need a video on this and a more simple how to do it steps. I just had my first car 6months ago, so I'm really a newbie. Any links would really helpful.
dwaynexxx is offline
post #9 of 9 (permalink) Old 01-13-2011, 05:41 AM
I came across this general step instruction about how to rotate tires. Is this your first time to do this? I'll try to find something that is specific to our make.
jackj is offline
