Buzzing noise while at stop after cruising - Page 7 - Kia Forum
post #61 of 67 (permalink) Old 09-24-2010, 12:11 PM
MSUStevo's Avatar
Drives: 09 Rondo LX, 4 cylinder, Java w/ Black interior, 5 seater
Mr. Rondo went back to the dealer on Monday for the A/C compressor replacement and to check out the new rattle during mild to heavy acceleration
I'm pleased to report that all the noises are gone and I'm once again the owner of a quiet car!!!
They said the rattle came from stones that had gotten on top of the converter heat shield
To my pleasant surprise, my dealer also mounted the front and rear mud guards I'd purchased at no charge will doing the other work. I can't say enough good things about how the folks at Kia of Lansing have handled this whole thing. Very professional and up front from start to finish
PS - While looking through the recent posts I see someone requested part numbers. I need to run right now, but I'll see about pulling out the receipts and seeing if they listed the actual part numbers
MSUStevo is offline
post #62 of 67 (permalink) Old 09-24-2010, 04:34 PM
imperialman's Avatar
Drives: 09 Rondo lx 4 cyl 2008 Corolla,2001 Taurus,1960 Chrysler imperial,1967 Chrysler imperial
I went through this problem with my 09 Rondo.
Pretty much exactly as you describe.
Intermittent buzzing noise like a florescent light fixture and hard to duplicate.
The long story short is that with mine it was a solenoid in the transmission.
The dealer after having the car for a day and finally duplicating the buzzing noise said that "they all do that to some degree"
But the dealer also stepped up to the plate by saying that the buzzing was quite a bit louder than normal with my Rondo and worked with the local Kia rep to get me a new transmission.
The understanding being that if the noise came back I would probably have to live with it. So 3000 miles later everything is still quiet
For what its worth I had about 19,000 miles on my Rondo when the buzzing became annoying, at least to me .
Also it seemed to be more prevalent when it was hot weather for what ever reason?
imperialman is offline
post #63 of 67 (permalink) Old 09-24-2010, 04:38 PM
Oops...read an earlier post from this summer and see that my Rondo had 21,000 miles on it when they replaced the transmission.
post #64 of 67 (permalink) Old 09-27-2010, 05:38 AM Thread Starter
grey08's Avatar
Drives: 08 Rondo, EX 2.4I
Well looks like I will have to convince the dealer to R&R the transmission to get rid of my buzzing.
Likewise the noise is worse in the "heat"
Great feedback from everyone.
grey08 is offline
post #65 of 67 (permalink) Old 09-27-2010, 10:18 AM
MSUStevo's Avatar
I looked at the repair receipts. The numbers listed after the parts are identified as "FP Numbers"
Replaced Transmission Assembly and Flushed Cooler Lines
45000R00 RH0 NA4 CA5
Reman Trans 45000-39AR2R
SPIII ATF UM010-CH002
PS4 P/Steer UM010-CH043
Core Return 45000-39AR2R
Replaced AC Compressor and Recharged
97701R00 N94 C31
Compressor Assy 97701-1D100
Freon 134A
Replaced Serpentine Belt Idler Pulley
25287R00 N21 C11
Idler-Drive Belt 25287-25010
MSUStevo is offline
post #66 of 67 (permalink) Old 12-14-2010, 07:52 PM
Drives: 2017 Kia Sorento LX AWD
Quoted: 6 Post(s)
97701R00 N94 C31
Freon 134A
25287R00 N21 C11
Is your car still "buzz" free? It seems my 2009 2.4 Optima is doing this as well as my friends 09 2.4 Sonata. It is coming from the transmission in both cars.
brsexton is offline
post #67 of 67 (permalink) Old 10-25-2012, 06:33 PM Thread Starter
grey08's Avatar
Still buzzing, just ignore it now, however does have an occasional nasty 2nd to 3rd shift flare. Seems to happen if you accelerate slightly then come off the throttle a bit. Not much luck with the dealer on this one as they never notice it on test drives.
grey08 is offline
