Thanks Narvo,
The shop manual I was directed to by this forum shows the same steering rack and front suspension for the V6 and I4. I haven't taken the time to sort through the rest of the front end components yet. The manual is located here
Kia Global Information System (KGIS)
There is a lot of info on this site, including the "pit stop" section. I found this bulletin #KT2005061705 (Kia Technical Assistance Center Guidelines) there and pasted it below. I guess I should be asking Kia if the form "Technical Assistance Center worksheet P/N UN980 PS001" was filled out since no resolution was found for my problems after at least three visits. Anyone ever have one of these things filled out by their dealer?
The purpose of the Kia Technical Assistance Center (TechLine) is to assist Kia dealers with Kia
vehicle repair related technical problems.
When to Use the Technical Assistance Center
• When all normal repair resources have been used (i.e., Service Manual, TSBs, Technician
Times, KSIS, kdealer.net, DPSM assistance, etc.)
• Vehicle is in for the second repair attempt or greater than 1/2 hour diagnostic time without
being able to find the source of the problem.
How to Use the Technical Assistance Center
• Fill in the Technical Assistance Center worksheet P/N UN980 PS001 (available on kdealer.net,
Technical Forms section) with the following information and have it ready before calling:
* Complete VIN * Production date
* R.O. Number / Mileage * Owner’s name
* Repair history - number of repair attempts
* Explanation of problem condition (customer and dealer description)
• Each vehicle repair will be entered into the TechLine database and a case number will be
given to the caller for follow-up calls and case closure.
Additional Guidelines
• Only Kia dealers can use the Technical Assistance Center.
• Always have the vehicle present and attempt a repair before calling.
• TechLine does not authorize warranty claims.
• For help with Warranty issues, call the Warranty Hotline at 800-225-3217.
• For help with Parts information, call the Kia Motors America Parts HotLine at 800-542-5611
• To get radio codes for 1996 and 1997 vehicles, use your dealer DCS system as outlined in
TSB Volume 1, Accessories 001.
• All TechLine cases must be closed within 30 days. Be sure to provide confirmation of the
repair as outlined below.
To close a case: 1. Call the TechLine and leave a message in the close case voice mailbox with
the case number and resolution.
2. Fax a copy of the TechLine worksheet with resolution to 949-470-2800
Technical Assistance Center Number: 800-494-4542
