The tire pressure light came on and would not go off despite the tires were pressured up correctly within 2 days after purchasing Saturday before last. Then on the Tuesday after purchase I put it in reverse and started to pull forward and it had a strange 3 to 4 beat pause and go similar to how a manual transmission would do if you "popped the clutch" too quickly. 3 days later it has a brief 2 beat pause while decelerating into a redlight. Then on last Friday, while the hubby was driving it, it did the "popping out the clutch" feeling again. The "popping out the clutch"-like event happens first thing in the morning when it is very cold.
The dealership has the vehicle now, says they got the tire pressure light repaired but do not know at this point what the "popping out the clutch-like event" is and are going to continue to try to reproduce it.
Anyone had this experience?
