Rear spoilers are one of the most popular auto accessories available on the aftermarket. From mild to wild, a rear spoiler can change the entire look of any vehicle. If you want the spoiler, which after mounting has a factory installed look, then the factory style spoiler is exactly what you need. We have an exclusive option from Pure, which you might find interesting. Click here to read more about this brand at CARiD.com.
Pure® - Factory Style Rear Lip Spoiler ill perfectly complement your car's fine lines, and its distinctive shape will set your car apart from lesser models. It delivers a sporty image that is easy to be recognized. Made from Fiberglass, installs easily with screws and gaskets, backed by a 3-year warranty. You can use it for better traction and to add a sporty look, but also include other advantages, such as increased fuel efficiency, added visibility, reduced car weight, and braking stability.
It is available in Unpainted and Painted versions (you can check the paint code by VIN# or with paint code labels, located at the driver side door jamb).
And what do you think of this stylish accessory for your vehicle?
