NO heat inside?? - Kia Forum
post #1 of 19 (permalink) Old 11-03-2006, 01:21 PM Thread Starter
Unhappy NO heat inside??
I have a 2004 Sorento EX and for some reason the heat just stoped working. Air is coming out but its just cold. Has anyone had of heard of this problem? I have an appointment but its not for two weeks and this is the wifes truck! She is not happy at all right now.
Thanks in advance!
G
greggsbluer6 is offline
post #2 of 19 (permalink) Old 11-03-2006, 03:48 PM
Inky's Avatar
First, is the air being pulled in as cold as the outside air or is it a bit warmer (but not warm enough)?
If it's cold, you could be looking at a plugged heater core. Another posibility is this.
Let us know what you find out.
-- Christian
Inky is offline
post #3 of 19 (permalink) Old 11-05-2006, 07:53 PM
darkangel's Avatar
Drives: 2006 Kia Spectra EX
Send a message via MSN to darkangel
heater core sounds more like it...maybe the thermostat also? someone told me along time ago that if the thermostat f's up than it could cause it to not blow hot air. could be wrong tho.
darkangel is offline
post #4 of 19 (permalink) Old 11-05-2006, 09:53 PM
Inky's Avatar
If the thermostat is stuck shut, then yes. Possibly also cause the engine to run hot or overheat. OP should watch the temp gauge (is there one?) to see if it runs higher than usual.
-- Christian
Inky is offline
post #5 of 19 (permalink) Old 11-11-2006, 10:36 AM
Raven1210's Avatar
Drives: 1999 Acura Integra
Gallery: 1
Its the other way around, if the thermostat is stuck open then there well be no heat. If its stuck shut then the car well over heat, But well still have heat inside. Thats why they say if your car is over heating put the heat on the windows deforst. It well help keep the tempeture down for a little bit longer to you get it to where ever you go.
Raven1210 is offline
post #6 of 19 (permalink) Old 11-11-2006, 11:08 AM
Inky's Avatar
Oh, had the stuck shut/overheat part right. I don't know what I was thinking on the heat. Thanks for clarifying that!
Wouldn't there still be heat if it's stuck open. It would just take longer, right?
-- Christian
Inky is offline
post #7 of 19 (permalink) Old 11-11-2006, 03:09 PM
Raven1210's Avatar
Gallery: 1
there would be heat but it would take a very long time to heat up. I had my thermostat pulled on my carmaro because it was overheating and i was 8 hours away from home. Once I started it up after being cool it took me a half a hour to get it blowing warm air. with a 4cyl i think it would still take atlest 20 minutes
post #8 of 19 (permalink) Old 11-27-2006, 11:29 PM
Drives: 2003 Mustang GT 2002 Kia Sportage
Smile Loss of heater output
I don't know if this relates to other KIA models but this is what caused loss of heater output on my 92,000 mile 2002 Sportage:
The position of the air temperature valve in the air conditioning housing under the dash (which determines how much of the total airflow is permitted to pass through the heater) was stuck. The valve position determines the warmth of the overall air flow that is sent into the passenger compartment. This door-like valve redirects air flow. In some positions such as defrost the AC comes on to dehumidfy the air to aid in clearing the windows during high humidity. The loss of heater output was accompanied by an unusually loud heater fan with low airflow. Daily driving round trip on a mile of dusty dirt road to and from our house produced a lot of dust in the unit. The dust, when mixed with AC condensate made quite a mess.
In my case, disassembly and a thorough cleaning of all moving parts solved the problem.
Dr. Detroit is offline
post #9 of 19 (permalink) Old 12-10-2006, 08:24 AM
stop driving your car immediately.
my wifes 2003 serento did the same thing she was low on antifreeze.
after filling (1 gallon low) i looked for a leak and found it on the bottom of the plastic radiator bottle (under pressure) replaced it myself at a cost of 120.00 from kia. this appears to be common over 60,000 but kia will not acknowledge this problem and if your engine over heats and has damage kia will not warrenty the motor
please let me know if this was the problem
GARBEAR is offline
post #10 of 19 (permalink) Old 01-03-2007, 09:30 AM
I'm getting the lukewarm air too, no leaks, full anitfreeze
How difficult is it to replace the heater core on a 2002 Sedona?
goonbutt is offline
  Kia Forum > Technical > Interiors and Exteriors
