2000 Sephia Door Panel Removal? - Kia Forum
post #1 of 7 (permalink) Old 02-28-2005, 12:04 AM Thread Starter
Hi everyone,
Thanks for the help with how to get to the rear speakers. Job took awhile but I eventually shoe-horned my old 4-way Pioneer 6x9's in there (reciprocating saws rock! :-)
Anyway, I want to upgrade my front speakers now, and if history holds true for cars in general, the door panels are going to be VERY easy to break (especially since I see only 1 real screw in each panel, inside the handle). So, before I start prying until it either pops off or breaks, I thought I'd see if somebody out here knows how to remove the panels cleanly to get access to the front speakers.
The car is a 2000 Sephia, manual windows and locks. What has to come off first? Where are the clips/fasteners all located? Any tricks or special tools needed (like, does the window crank need to come off first, and if so, how??)? Any special directions I'll need to push/pull?
Thanks in advance!
-- Evan
galtem is offline
post #2 of 7 (permalink) Old 02-28-2005, 06:49 AM
Premium Member
1fastkia's Avatar
Quoted: 16 Post(s)
Originally posted by galtem@Feb 28 2005, 02:04 AM
Hi everyone,
Thanks for the help with how to get to the rear speakers.* Job took awhile but I eventually shoe-horned my old 4-way Pioneer 6x9's in there (reciprocating saws rock! :-)
Anyway, I want to upgrade my front speakers now, and if history holds true for cars in general, the door panels are going to be VERY easy to break (especially since I see only 1 real screw in each panel, inside the handle).* So, before I start prying until it either pops off or breaks, I thought I'd see if somebody out here knows how to remove the panels cleanly to get access to the front speakers.
The car is a 2000 Sephia, manual windows and locks.* What has to come off first?* Where are the clips/fasteners all located?* Any tricks or special tools needed (like, does the window crank need to come off first, and if so, how??)?* Any special directions I'll need to push/pull?*
Thanks in advance!
-- Evan
Take the window crank off first.
then the screw in the holder thing there in the door.
then when you open the door there are 2 screws on the bottom of the door. there is also one on the siide of the door.
then there is a screw in the inside door handel.
you wil have to remove that piece that covers where the mirror is on the inside. it should come off now.
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #3 of 7 (permalink) Old 02-28-2005, 01:43 PM Thread Starter
Thanks, but how does the window crank come off? Is there a certian way it needs to be lined up? Is there a cap and a screw under it somwehere? Do you just pick someplace and start prying, or what? I don't want to break it and there doesn't seem to be an obvious way it is attached. Thank you in advance!
I'm looking for specifics -- I've broken door panels before out of ignorance and I'd rather not break these,
-- Evan
galtem is offline
post #4 of 7 (permalink) Old 02-28-2005, 04:16 PM
Premium Member
1fastkia's Avatar
Quoted: 16 Post(s)
-- Evan
if you kinda push the door panel in right around the crank you will see in there (tough to see) a clip. there is a tool you can get at the parts store to remove these. without the tool its kinda tough without scratching the panel. I hope this helps this is preaty much the only way i can think of to explain it! for the crank. if ya need other help with other directions i said just ask em.
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #5 of 7 (permalink) Old 02-28-2005, 07:59 PM Thread Starter
OK, I saw the metal pressure clip and manged to get it off with minimal scratching using a real thin screw driver to pry it off -- thanks! Door panels already have some scratches on them, so no big loss.
OK, I've gotten the two screws at the bottom of the door off, the one on the side, the 2 plastic screws near the hinge facing the interior, the one inside the bottom of the door "cup" you use to pull the door shut, and the popped the little cover off the one in the door opening handle itself and got that screw and the plastic trim piece off.
So now I'm down to clips, right? Or does that cover over the mirror control need to be removed first? I tried pulling and it seems really fastened well. What's next? Thanks!
-- Evan
galtem is offline
post #6 of 7 (permalink) Old 03-01-2005, 06:43 AM
Premium Member
1fastkia's Avatar
Quoted: 16 Post(s)
-- Evan
That piece over the mirror is just clipped in there pull it off it comes off tough and bends but it will be ok.
the rest of the door should pull off now. you gotta kinda pull up and then out to get by the window sill.
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #7 of 7 (permalink) Old 07-04-2005, 01:00 AM
BasSBraT's Avatar
Send a message via AIM to BasSBraT Send a message via Yahoo to BasSBraT
how would this be different for a door with power windows & lock on a 97? i need to do this too.
also the speakers i got for the front seem to be about 1/4 too big even tho the guy at "watts-in-a-box" said they were the model that would fit anything i can do about that? thanx in advance
BasSBraT is offline
  Kia Forum > Technical > Interiors and Exteriors
