Hi- 1) Found an answer to my question at an auto parts store that was open late on Sunday (hopefully the correct answer)... it takes a metal crush washer. 2) I pulled the oil drain plug again, and sure enough, there was a washer tightly adhering to the drain plug. After I managed to separate the washer from the bolt, I replaced the old ALUMINUM washer with another ALUMINUM washer (though the replacement one was much thicker), and 4) torqued the oil sump bolt to the SURPRISINGLY high torque level that the owner's manual recommended (after the cast aluminum sump pan cooled down so as not to damage the threads). Anyway, I think I am all set on this now. I plan to pick up a few spare drain plug washers from the KIA dealer and keep them available for my future oil draining sessions.
Out of curiousity, I wonder what the quick-oil change shops do regarding the washer and torque requirements when they put back the oil drain plug?
Also, has anyone had any oil filter issues with the KIA? Seems that the owner's manual is pretty blunt that there are "replacement" oil filters out there that could screw up the engine..... I chose a FRAM oil filter. Unfortunately, the location of the filter makes it quite difficult to visually determine how much you rotate the filter after initial contact. Guess I could have held some type of mirror between the filter and the firewall to see what I was doing...
Regards,
Bob-B
