Sedona Fault code P1295 - Kia Forum
post #1 of 2 (permalink) Old 09-11-2010, 12:11 PM Thread Starter
I have an 07 Sedona with the 3.8 engine.
The engine went into P2106 TAC System Forced Limited Power and displayed the following two fault codes:
P1295 Manufacturer Contrl Fuel Air Metering AND
P161B Manufacturer Contrl Auxiliary Inputs Auxiliary Outputs
The dealer indicated to me to change the Throttle Body position sensor which I did. During the change, I noticed a tear in the Air Intake Tube which I repaired with Gorilla tape to seal it up.
I also reset the check engine light by disconnecting the battery for about 10 minutes.
The engine will still not run above an idle and sounds like it is getting a lot of air and no fuel (kinda a WAAAAAA) sound when you press on the accelerator.
Any thoughts?
I was kinda hoping to find out more about the codes.
Thanks,
Ken
KiaKen8 is offline
post #2 of 2 (permalink) Old 10-13-2010, 12:07 PM
AlR
P161b
My 2007 Optima threw P161B, P1295 and P2106 this morning. I think it is in the limp mode because it will not run much above 20 mph. I have been searching for info on these codes with little luck ; any help out there?
AlR is offline
