Old 09-15-2006, 10:56 AM   #1 (permalink)
daventrish93
Question 2003 sedona keyless remote programming
I purchased a new remote for my sedonda. I cant find a programming form or procedure to program the second remote. Any Ideas??
daventrish93 is offline   Reply With Quote
Old 09-16-2006, 10:02 AM   #2 (permalink)
Campduck
Here is what you do.
1. Use a jumper wire, connect the jumper between terminal 12 and terminal 16 of the diagnostic connector.
( It should look like this)
2. Turn the ignition switch to the on position
3. Press the lock button two times.
4. If you have a second remote press the lock button two times.
5. Turn the ignition switch off and pull the key out.
6. Disconnect the jumper wire from the diagnostic connector.
7. Test each remote for function.
Might work for you, give it a try.
Campduck is offline   Reply With Quote
Old 09-19-2006, 06:49 AM   #3 (permalink)
daventrish93
Thank you and i will try it...
Old 11-29-2006, 04:18 AM   #4 (permalink)
alimands
daventrish93 ,
Did you have any joy with this procedure? I have had a few problems in the past and was thinking of trying this. Fell at the first hurdle & couldn't even find the diagnostic connector. Do you know where it is located?
Any help would be appreciated.
alimands is offline   Reply With Quote
Old 01-01-2007, 04:02 AM   #5 (permalink)
txwylde
I have a 2004 Kia Sedona and tried doing the jumper trick and that does not work. From what I understand, there is the door unlock module undernearth the shift lever that has a button that you can press and it will program the codes for you. I cant find any digrams that show me where this button's exact location is or how to get to it.
txwylde is offline   Reply With Quote
Old 01-01-2007, 04:10 AM   #6 (permalink)
txwylde
The Sedona Service Manual incorrectly identifies the programming terminals at the under-hood diagnostic connector, therefore the following programming procedure should be followed.
Note: At this time only one remote can be programmed into the RKE memory; attempting to program a second remote will cancel the original.
1. Open hood and locate diagnostic connector near battery.
2. Jump pin 5 to pin 17.
3. Turn ignition switch to the on position.
4. Press LOCK button of transmitter two times.
5. Turn ignition OFF and remove key.
6. Disconnect jumper from diagnostic connector.
7. Check for lock and unlock operation, horn will operate when locking.
Old 02-08-2007, 10:09 AM   #7 (permalink)
abayou
So, which pins are the right ones; 5 & 17 or 12 & 16. Please advise. I have a 2002 Sedona, and I also just purchased a remote for it...
Thanks.
abayou is offline   Reply With Quote
Old 02-17-2007, 05:19 PM   #8 (permalink)
senaatis
Another person in hop of right advise...
Can any one confirm if the method above works successfully?
I am looking for 2002 Sedona model programming.
senaatis is offline   Reply With Quote
Old 03-07-2007, 12:37 PM   #9 (permalink)
SeanTrantham
I have a 2005 Sedona. I broke one of the transmitters, and would like to program the car to accept the code. Anyone know which jumpers will work? I really don't want to have to pay Kia $40 to do this service.
SeanTrantham is offline   Reply With Quote
Old 03-29-2007, 02:08 PM   #10 (permalink)
psychocandy
Am I right in saying that if you set one of your keyfobs this way that any other you've got will stop working?
Why give out 2 then? Spare?
psychocandy is offline   Reply With Quote
