Old 05-13-2006, 12:45 PM   #1 (permalink)
shelly1snj
hey all....im STRESSING!!!!!!! it is the timing belt and we follow the diy but now we cant get the belt on and the directions on the settings are a little difficult to understand to a newbie with no mechanical experience.So.... someone else replied with my same concerns but i dont see a reply so here goes ....the belt is off and it is missing like 7 teeth in a row, i found out i have a non-inteference engine from what everyone has been replying and im a happy about that but how do we put the belt on and at what markings...
OUR back plate has an "I" indent very easy to see and an "E" indent very easy to see (THEY ARE ARE MARKED ON THE BACKPLATE AT APPROXIMATELY 10 MINUTES OF 12 AND 10 MINUTES AFTER 12 ON THE OTHER) SO MY QUESTION IS:
on the left side do i line the i on my wheel to the i on the back plate and on the left side the e on my wheel to the e on the back plate(EVENTHOUGH THAT IS CLEARLY NOT 12'O CLOCK)
also...i see white paint or something white dot mark on the "S" AS WELL as another replyer did----WHAT DOES THAT MEAN?
someone please help and soon cause my car is torn apart and im exhausted over it all ready. thank you all in advance
shelly1snj is offline   Reply With Quote
Old 05-13-2006, 12:47 PM   #2 (permalink)
skidoofast
go th the top of this page and click in view new posts, i left a reply that will help you in one of your previous topics
Jeremy Owens
Muscatell Kia
skidoofast is offline   Reply With Quote
Old 05-13-2006, 12:59 PM   #3 (permalink)
skidoofast
here are diagrams from the service manual hope this helps
loosen the tensioner, use a screwdriver or prybar and pry it back then tighten it in the back position, after the belt is in place and all marks are lined up then loosen the adjuster bolt and it should spring back to tighten belt, tighten the bolt and check the deflection loosen and use screw driver to apply pressure to the tensioner until deflection is correct, tighten tensioner and rotate engine 2 times and recheck the alignement marks
Jeremy Owens
Muscatell Kia
Old 05-13-2006, 01:04 PM   #4 (permalink)
shelly1snj
THANK YOU THANK YOU THANK YOU...........it is so much better understood with a diagram to look at...so why would they mark the backplate-im assuming now just to tell u which side is what....thank you thank you thank you soooooo much.
Old 05-13-2006, 01:06 PM   #5 (permalink)
skidoofast
your welcome, just for future reference you can use the top bar on this forum to check messages and to see the latest posts, it is a verry usefull tool
Jeremy Owens
Muscatell Kia
Old 01-03-2007, 03:35 PM   #6 (permalink)
maxx merit
did it work???
maxx merit is offline   Reply With Quote
Old 07-11-2007, 04:52 PM   #7 (permalink)
dennisa01
Hey I think you and my husband had the same nightmare. He is asking the exact same questions. My only real concern is that he is suppose to be fixing the water pump??!!
dennisa01 is offline   Reply With Quote
Old 10-16-2007, 02:56 PM   #8 (permalink)
redmasta
I'm just wondering. I need to replace my timing belt on my Sephia. How long does this usually take to do? I have mediocre auto skills.
redmasta is offline   Reply With Quote
Old 10-17-2007, 01:37 AM   #9 (permalink)
sportage4x4
you have to remove the timing belt to change the water pump on that engine.
Matt
MT Engineering
Go Fast Rio Goodies
