Old 05-01-2006, 01:57 PM   #1 (permalink)
76chevyc10
My wifes 2001 Rio engine light came on, I connected a tester to it and I got two error codes a 101 and a 400. I turned the light off, it stayed off for three days and came on again giving the same error codes. Anyone have a fix for this problem?
76chevyc10 is offline   Reply With Quote
Old 05-01-2006, 02:27 PM   #2 (permalink)
KiaMech
KiaMech's Avatar
Drives: 2003 Kia Sorento
Sounds like you're going to need a mass air flow sensor. Have it checked before replacing it though. Sometimes things get stuck on the film inside, so you can take a look at that and make sure nothing is stuck in there, but it will probably need to be replaced.
Will the scanner you have show any data on the MAF?
KiaMech is offline   Reply With Quote
Old 05-01-2006, 02:36 PM   #3 (permalink)
76chevyc10
No my scanner will not show any data on the MAF, will Auto Zone test the mass air flow sensor? Thanks for your help!
Old 05-01-2006, 03:01 PM   #4 (permalink)
mwrobe1
mwrobe1's Avatar
Drives: 2006 Kia Rio
P0101 : Mass air flow (MAF) sensor circuit range/performance problem
I had one eventually go out on a Buick Lesabre I owned...you can clean it...just be very careful with it. And don't use alcohol...a cotton swab and little water will work fine...the exposed metal in the MAF sensor is very sensitive (I believe its platinum wires wrapped around ceramic bobbins...not the bass fishing type either LOL). If you're a real geek...put voltimeter on the the thing...when the one I had in the LeSabre went...it wasn't putting out any voltage readings at all. Bottom line is that when air passes over the sensor...a voltage reading should be realized and sent to the ECM...if that voltage reading is out of range or not present...the MAF needs to be replaced.
Elwood: It's 106 miles to Chicago, we got a full tank of gas, half a pack of cigarettes, it's dark and we're wearing sunglasses
Jake: Hit it
mwrobe1 is offline   Reply With Quote
Old 05-01-2006, 04:07 PM   #5 (permalink)
KiaMech
KiaMech's Avatar
These have the hot-film sensors, not the type you are describing. They can still be cleaned though, if that's the problem.
You can use a voltmeter to check it, but you wouldn't be able to see any waveform problems.
I have no idea if Autozone can check the sensor, sorry.
Old 05-02-2006, 11:28 AM   #6 (permalink)
1fastkia
depends on the autozone.. some do some dont call them up and see..
2008 Sportage
10K Hids
Chrome Door Handles
More to come
1993 Honda Del Sol (vtec)
