On the SpecSX it's held on by plastic rivets located in both wheel wells, under the closed hatch on top of the cover, and under the car...in assorted places...
The "rivets" have a philips type screw in the center and if you slide a pocket knife in along the edge where the "philips" makes contact and gently apply pressure to lift the screw while turning it they will back out and can be re-used... Be careful of the amount of heat used and move the heat gun/hair dryer often...If kept in one location too long you WILL distort the plastic. You need only enough heat to barely soften the plastic than use something with a fairly large contact area to push the dent back out. Take your time and don't push to hard or too fast...
