HELP: 2005 Kia Spectra - Front Wheel bearing replacement. Where do i find info? - Kia Forum
post #1 of 15 (permalink) Old 02-20-2012, 02:01 AM Thread Starter
I need to change a front wheel bearing on my 2005 Kia Spectra. Does anyone know where I can find step by step info on this? I am finding all kinds of different opinions. Possibility of dealer special tools, etc...
I just want to know where I can find actual facts...lol
thanks.
csrMark is offline
post #2 of 15 (permalink) Old 02-20-2012, 08:06 AM
DavesSpectra's Avatar
Quoted: 352 Post(s)
Look at kiatechinfo.com. You need to be running Windoz (XP/Vista/7) and have Internet Explorer (6 or higher), and download Adobe SVG (scaled vector graphics) plug in to "see" graphics (pictures). The membership is free and there is all the info you will need. The site has a learning curve and sometimes seams hard to search but the info is there.
DavesSpectra is online now
post #3 of 15 (permalink) Old 02-20-2012, 12:48 PM Thread Starter
Thank you for the quick reply. However, this is another problem I seem to be having. Maybe because it's the U.S.??
Many times, I don't get a listing for a 2005 Spectra. This just happened under "2005" in the kiatech site.
Look...
2005 (6)
2005 Sportage (KM) Owners Manual
2005 Sorento (BL) Owners Manual
2005 Sedona (GQ) Owners Manual
2005 Rio (BC) Owners Manual
2005 Optima (MS) Owners Manual
2005 Amanti (GH) Owners Manual
I also have problems buying parts for this same vehicle. I went for rear drum brake wheel cylinders and no auto parts store had a listing for it?
csrMark is offline
post #4 of 15 (permalink) Old 02-20-2012, 12:59 PM Thread Starter
I found it. Great instructions.. Yes, a little bit of a learning curve. THANK YOU.
csrMark is offline
post #5 of 15 (permalink) Old 02-20-2012, 03:13 PM
Quoted: 352 Post(s)
Glad to be of assistance .... Now to find the part you need go to rockauto.com..
I have been purchasing from them for my KIAs and family Hyundais with excellent results.
post #6 of 15 (permalink) Old 04-01-2012, 10:27 AM
we did it just this past weekend without the tools kia uses at the dealership which i listed part numbers below.. A press and a bit of toying around with it and you can get it out. It's hard to push the hub out of the steering knuckle (you have to build a crazy contraption and make sure you have a solid base to use the press) but once you get that your pretty much home free. Also watch when your disconnecting the lower ball joint, as it seemed to want to spin on us (its tapered and usually has a pin through it or a square end you can grab to stop it from turning but i didn't see it on this one) so we used a bit of heat and tapped it with a hammer and out it came (be careful with heat around the rubber on the balljoint you need to keep that tight and sealed) Anyways good luck i listed the tools needed below if you want to do it the pain free way
Oh and one more thing, i am happy to say the car is silent and no more humming!
EDIT: Curious was yours the driver side or passenger side Wheel bearing? Mine was DS
09517-21500
Front hub remover and installer
Removal & installation of the front hub. (use with
09517-21600)
09517-21600
Knuckle arm bridge
Removal of the front hub. (use with 09517-21500)
DeadmanX is offline
post #7 of 15 (permalink) Old 04-01-2012, 01:53 PM
Quoted: 352 Post(s)
DeadmanX..
Your posts in Oct 2011 said you had 71k miles on the car... How many miles were on it recently when you changed the front wheel bearings? Seams quite low for bearings to fail.
Did you take any pictures that you can post?
post #8 of 15 (permalink) Old 04-03-2012, 07:01 PM
Car has 78k on it. It was odd because it wasn't really that bad to where the wheel would move when you grabbed it and wiggled it, but it was just bad enough to make some noise. Like i said before problem solved and car actually feels a ton better! Sorry i didn't take any pics but if anyone has any questions about the change feel free to ask away and i can guide ya along
DeadmanX is offline
post #9 of 15 (permalink) Old 04-28-2012, 12:12 PM
Drives: 2005 Blue Kia Spectra5 and a 96 Turbo Honda civic and a 99 subaru outback with a 2.5 rs turbo motor
Gallery: 10
Quoted: 5 Post(s)
Send a message via Yahoo to tt2jzgtes Send a message via Skype™ to tt2jzgtes
im bout to say i replace my driverside hub bearing and now the left 1 is actin up i was going to make a vid on how to do it. if you have not done it already..
tt2jzgtes is offline
post #10 of 15 (permalink) Old 05-13-2012, 01:50 PM
Go for it, it would be a huge help!
DeadmanX is offline
  Kia Forum > KIA Models > Kia Cerato, Shuma & Spectra Forum > Cerato (2003 - 2008) & Spectra5 (2004)
