2005 Spectra5 Fast turn signal - Kia Forum
post #1 of 4 (permalink) Old 09-20-2011, 11:18 PM Thread Starter
Drives: 2005 Spectra5
Hi,
Just purchased a 2005 Kia Spectra5. Wouldn't you know, after a week of driving, the left turn signal blinks twice as fast as normal. Checking outside of the vehicle, both front and rear signals illuminate, but are much dimmer than the correctly functioning passenger side.
Doing a forum search, I saw it suggested that this could be a ground/current issue. Thus far I've:
Replaced all four turn signal bulbs (front, rear, drivers and passengers), cleaned the battery contacts, and cleaned both ground contacts where the wiring harness is bolted to the hood.
I've also noticed that the headlamps do not illuminate until the car is cranked. I'm not sure if this another symptom of the problem, or just normal operation for the vehicle.
Any other ideas as to what I can do to narrow down the issue? Thanks!
fireburns is offline
post #2 of 4 (permalink) Old 09-25-2011, 04:15 PM Thread Starter
For those interested, it was a contact issue with the front signal bulb and socket.
I ended up removing the battery to better get at the assembly and removed both the bulb from the socket and the socket from the wiring harness. I cleaned each connecting area and made sure the bulb was seated all the way. Judging by the condition of the original bulb, I'd say I had a failing bulb, but did not properly seat my new one, which is why the fast signal issue didn't go away.
Hope this helps somebody else who might happen to have the same issue...
post #3 of 4 (permalink) Old 11-29-2011, 09:15 PM
Drives: Black 2007 Spectra EX, 19.2mm Tib rear bar.
Good info. The bad contact was acting just like a bad bulb, hence the fast blinker.
LAMRONH is offline
post #4 of 4 (permalink) Old 01-05-2012, 05:38 PM
I had same issue and it was the ground wire from wire harness right by battery bolted to frame
Just a FYI
Billiardking is offline
  Kia Forum > KIA Models > Kia Cerato, Shuma & Spectra Forum > Cerato (2003 - 2008) & Spectra5 (2004)
