Hopefully this works.
Dave you can edit the how to on this.
1st I spliced into the 12v line at the sensor and hooked up directly to the battery, it did not fix it. 2nd Ispliced into the ground line at the sensor and hooked it directly to frame, it did not fix it. 3rd I spliced into the signal wire at the sensor, ran a wire from there to the instrument cluster and spliced that into the signal wire right at the connector. I believe its the wire in the middle. I will do this tonight and will update you guys if it works. if not next thing to do is replace the TransControlModule (JohnCamp)
When your speedo only works for the first 10-15 mins of driving and all of a sudden it stop working or it only works when its 30degrees or lower outside temp.
This is how you fix that problem:
Things you need: 16g wire about 3-5 feet, wire cutter/snips, heat shrink to wrap wires together or electrical tape, needle nose grips and a Philips head screw driver
1:locate your speed sensor
2:remove speed sensor wire( use needle nose grips to remove locking clip)
3:splice into the wire (Green wire with orange stripe) don't have to cut the wire completely just enough to expose the wire so you can tap into it.
4: tap into the expose wire and put electrical tape or heat shrink tubing on it to prevent any corrosion in the future
5:feed your wire into the firewall(probly gonna have to drill a hole in your firewall best place to drill is about 3" bellow the brake booster) I already had a couple of holes pre drilled in my car since I have installed a 0g wire to run my amp and 16g wire to run my horn for my alarm airhorn.
6: remove your speedo (2 Philips head screw attach the cover for the speedo unscrew that and pull out cover
7: 4 more Philips head screw holding the speedo itself and pull out the speedo
8ull out speedo and tilt it forward the harness to your right is the one you want to tap into (green wire with orange stripe)
9:tap into it and put tape on it.
10ut everything back together
Goodluck
I would post the pics but I don't know how to add pics to edited post.
Goodluck
