KIA 20-pin diagnostic connector diagram - Kia Forum
 4Likes
post #1 of 17 (permalink) Old 06-26-2007, 05:32 AM Thread Starter
Dear All of KIA members,
I am a problem is not found, please help about pin out diagram of Spactra KIA (20 pins).
Which pin was connecting to engine check light?
I knew that, fault code is include of long, short blink and pause time but how is time format of fault code blink?
How is time of short, long and pause pulse?
This is its connector:
BAT Auto Technical-Professional mechanics giving advice-An Educational Site w/ OBD2 Trouble Codes and Technical info & Tool Store.
Thank you for your answer
Duong
dtdauto is offline
post #2 of 17 (permalink) Old 06-26-2007, 05:50 AM
Drives: 1999 Kia Elan
Quoted: 380 Post(s)
Welcome to the forum.
The link that you posted shows the jumper you must use on the diagnostic plug.
It also describes how to count the short and long pulses to find the code.
Your link describes it better than I can - Possibly you need to get someone translate to this to Vietnamese for you.
ron1004 is offline
post #3 of 17 (permalink) Old 06-26-2007, 09:51 AM Thread Starter
Hi you,
The link that only describle is short blink and long blink but not detail that time of short blink and long blink as well as pause and its loop-circle. for example: short blink pulse is 500 ms, long blink pulse is 1500 ms.... loop circe is forever...
with toyta is OK: Toyota Engines - auto tune up using codes, Example models: Hilux Surf, Sienna
but KIA is Kia Engines - auto tune up using codes, Example models: Optima, Rio not clear.
I want to detail pin out diagram describle as where is GND-pin and +12V Bat-pin?... and code format decribles is more detail
If you found then send link to me please.
Thank you very much
Duong
dtdauto is offline
post #4 of 17 (permalink) Old 06-26-2007, 10:32 PM Thread Starter
Question
Hello All,
I am still waiting for your information.....
Do you know about KIA diagnostic connector and fault code format ?
Help me please!
Thank you very much
dtdauto is offline
post #5 of 17 (permalink) Old 06-26-2007, 10:43 PM
Quoted: 380 Post(s)
See the attached picture which shows how the jumper must be used - I use a paper clip - connect the jumper then switch on the ignition (not starting th eengine) then you will see the 'Check Engine Light' flash.
Watch this for some time and you'll soon note the long flash verses short flash and similarly the short pause verses long pause, then use the link to decifer the code.
Name:	OBD2 Plug - 2.JPG
ID:	1808   Click image for larger version
Name:	OBD2 Plug - 1.JPG
ron1004 is offline
post #6 of 17 (permalink) Old 06-27-2007, 12:27 AM Thread Starter
Thanks Ron1004,
Thanks for your help
in fact, I am writing a software on PC to get MIL/OBD-I code for some Asian vehicles. Present, I have not any KIA vehicle here to get sample code format for programming. Therefore, I need detail decrible of code format for software writes.
if you are free, could you be experimental trying in your car and get exact information of short, long, pause time and loop circle of the check engine light?
I will give this software to you when it is completed.
Please visit my website: DTDAUTO TECHNOLOGY TEAM HOME PAGE - SCANTOOL- AUTOMOTIVE TRAINING - AUTO REPAIRING - VEHICLE FAULT CODE READER to know about my works
Please send to private Emai: dtdung@iop.vast.ac.vn
Thanks for yours answer
Duong
dtdauto is offline
post #7 of 17 (permalink) Old 06-27-2007, 11:31 PM Thread Starter
hello Ron1004,
I know, I have been disturb to you
Today I just have found a 1.6 Kia Spectra from friend. I have tested with unplug some sensor. I have turn ON ignition key and run engine duration more 3 minutes. stop engine and jumper GND-pin to Engine test-pin as guide on BAT Auto Technical-Professional mechanics giving advice-An Educational Site w/ OBD2 Trouble Codes and Technical info & Tool Store..
But, Check engine light is not operation. I only turn on duration 03 sec and turn off when engine is runing.
I have tried many times but result is not change
Do not any flash a bit.????????
please help me is why?
Thank you very much?
Duong
dtdauto is offline
post #8 of 17 (permalink) Old 06-28-2007, 12:13 AM
Quoted: 380 Post(s)
If you disconnected a sensor with the engine running, and the CEL (MIL) should come one and it will generate a fault code and store this in memmory.
Turn the ignition OFF, then connect the jumper, and then turn ON the ignition without starting the engine, and now the CEL (MIL) light should flash showing the codes stored in the ECU.
It is possible that the Spectra you have is OBDII and possibly in this case the flashing CEL does not work. This I am not sure on, so you need to check.
I do know that the flashing CEL works on OBI.
ron1004 is offline
post #9 of 17 (permalink) Old 12-11-2009, 12:25 AM
do you know how to connect the kia 20 pin wire to a OBD2 wire ?
since i only has a obd2 with 16 pin.could it be check with obd2 scanner 16pin connector adapter?
i get the inform it needed a HI -Scan pro tool to diagnosis it. but the tool was too expenses. could somebody give me some idea?
smitty79 likes this.
michaelisi is offline
post #10 of 17 (permalink) Old 12-29-2011, 06:38 AM
This is my second post in this forum.. I am sorry, and apologise to start this way, but I had a problem with my Kia, and doing a search was how I found you... hope my next post be to help or simply to speak...
I have a 98' KIa Shuma that won´t start... the mil light turned on, and engine stopped.
I got 9 short blinks, then a little pause, 8 long (at least more long) blinks, a little pause again, and then 6 short blinks. After a while, the same again.
Is that code 95? I can´t find it... or maybe I am not calculating the fault code well?
Please, help me
Alif40 likes this.
josepz is offline
  Kia Forum > Technical > Car Audio, Video & Electronics
