KIA 20-pin diagnostic connector diagram - Page 2 - Kia Forum
 4Likes
post #11 of 17 (permalink) Old 12-29-2011, 08:44 AM
Drives: 1999 Kia Elan
Quoted: 383 Post(s)
That sounds like a code 9, and code 86, however I don't see code 86 on the list.
Try taking it somewhere to get the codes read.
Alif40 likes this.
ron1004 is offline
post #12 of 17 (permalink) Old 01-02-2012, 08:13 AM
Originally Posted by josepz View Post
This is my second post in this forum.. I am sorry, and apologise to start this way, but I had a problem with my Kia, and doing a search was how I found you... hope my next post be to help or simply to speak...
I have a 98' KIa Shuma that won´t start... the mil light turned on, and engine stopped.
I got 9 short blinks, then a little pause, 8 long (at least more long) blinks, a little pause again, and then 6 short blinks. After a while, the same again.
Is that code 95? I can´t find it... or maybe I am not calculating the fault code well?
Please, help me
If thats a 1998 your working on, it should be OBD 2, which means you can connect a cheap OBD 2 scanner and pull the codes without counting flashes.
Cheap $20 code reader at the auto parts store.
Mm
Mmfh is offline
post #13 of 17 (permalink) Old 09-14-2014, 03:00 PM
Drives: RIO LS 2002(made2011)& kia pride(2012)
Originally Posted by ron1004 View Post
See the attached picture which shows how the jumper must be used - I use a paper clip - connect the jumper then switch on the ignition (not starting th eengine) then you will see the 'Check Engine Light' flash.
Watch this for some time and you'll soon note the long flash verses short flash and similarly the short pause verses long pause, then use the link to decifer the code.
Hi
can i use jumper for my kia rio 2002 without OBD-II ? and R&Q terminal must be jumpered
thanks
vahid134 is offline
post #14 of 17 (permalink) Old 09-14-2014, 03:21 PM
DavesSpectra's Avatar
Quoted: 359 Post(s)
No...
The 2002 no longer supports "check engine" flash codes...
You will need to get an OBDII reader/scanner or have your mechanic read the codes for you... You could also buy an OBDII reader on the web and do it yourself...
DavesSpectra is offline
post #15 of 17 (permalink) Old 05-07-2015, 12:06 PM
Originally Posted by DavesSpectra View Post
No...
but my car haven't OBDII port.it only have this in hood
vahid134 is offline
post #16 of 17 (permalink) Old 05-07-2015, 12:40 PM
Quoted: 383 Post(s)
You can jumper the pins on that diagnostic port and count the flashes of the CEL to get the codes.
PS. Please remove the advertising link in your sig.
Name:	DLC Plug - 1.JPG
vahid134 likes this.
ron1004 is offline
post #17 of 17 (permalink) Old 05-08-2015, 12:24 PM
thanks ron 1004
vahid134 is offline
  Kia Forum > Technical > Car Audio, Video & Electronics
