Go Back   Kia Forum > Technical > Car Audio, Video & Electronics
Old 09-22-2005, 11:22 PM   #1 (permalink)
dangerz0ne's Avatar
I just installed the modulator and it is awesome. Direct connection to the ipod. If anyone is interested here is my site with step by step instructions with images. Jamie.
http://www.atlanticcomfortsystems.com/ipod/
dangerz0ne is offline   Reply With Quote
Old 09-23-2005, 01:11 AM   #2 (permalink)
Nice work, man, and cool step-by-step. I actually pulled instructions somewhere off this forum too on how to get to the head-unit, and once I managed to wrestle the vent clips free, it was easy going from there.
I didn't have to do any drilling at all -- one thing I like about the Sorento is that it's got all these power points. I use a Monster Cable low-profile charger and keep it plugged into the power point right behind the center console (facing the passengers) and then run the cable just under the lip of the center trim. So I still have the one in front of the shifter available for charging my phone or what-not.
Question -- why did you go with the FM modulator? Does it give better sound than auxiliary input? Or does your head unit not have auxiliary input?
My iPod is connected to the h/u through the AUX inputs, just had to run it through a ground loop isolator ($16 from Amazon) to get rid of the electrical noise, and then I ran the audio cable inside the coils of the charger cable, so there's no mess of wires. I've mounted an Arkon PDA cradle (removed the ratcheting arm so that it doesn't stick out quite so far) just to the left of the dashboard clock (made my own plastic insert so I could just use 3M mounting tape), so when it's docked the iPod sits right next to the h/u display.
Will try to put pictures up over the weekend.
monster is offline   Reply With Quote
Old 09-23-2005, 05:01 AM   #3 (permalink)
Hello,
I don't need to fit but looked at the the Pic's, nice very nice and
step by step, great.
I'm a little surprised with the FM modulator, I mean from a sound point of view.
Seacam
Old 10-04-2005, 10:37 PM   #4 (permalink)
Here's what I used for my install:
- Arkon CM131 ratcheting PDA mount
[attachmentid=786]
- Monster Cable iCharger (low profile, with dock connector and line out)
[attachmentid=787]
- 6' RCA male to stereo jack (3.5mm) cable
[attachmentid=788]
- Scosche Eso34 ground loop isolator
[attachmentid=789]
The only tools I needed were scissors, some 3M mounting tape, a nail file, an old plastic slate (one of my old dive slates), and a couple of black plastic tiewraps.
My first option for mounting was someplace a little lower, like where dangerz0ne drilled the hole for his switch, but with the arm out and the iPod in, it got in the way sometimes when steering or when reaching for the ignition. Might've also caused problems if I have to remove the vent panels in the future, as the ratcheting arm's base is a bit big.
In the end, I ended up getting rid of the ratcheting arm and then cutting a plastic insert (my dive slate) to replace the back of the mounting clip, so that I had a surface to attach the mounting tape to. And I put it high on the dash, right next to the clock and the stereo, like so:
[attachmentid=790]
My head unit has an auxiliary input, so after opening up the middle panel just like dangerz0ne did, all I really had to do was plug in ground loop isolator (it uses RCA jacks, so it was really just as simple as plugging in) and then plug in the cable. The isolator, I taped to the top of the head unit, padding it with some foam so it doesn't rattle about. The cable, I dropped behind the vent to come out under the dash.
I didn't wire a power source, opting instead to use the power point in the back, since no one really sits back there anyway. That also keeps my front power point free to charge my phone or whatever. I leave the charger permanently plugged in, so whenever the iPod is connected, the battery gets charged.
[attachmentid=791]
And then I just ran the charger's cable around the side and under the lip of the center panel (you can bend it back to tuck the wires under)...
[attachmentid=792]
...until someplace just beneath the dash, where I start to thread the audio cable through the middle of the coils, so there isn't a mess of cables.
[attachmentid=793]
I used the tiewraps to clip the two wires together once the audio cable exits the last of the coils, and also right after the stereo jack head, when it's connected to the line out of the iCharger. The PDA mount assembly slips onto the peg of the mount clip that was already taped on the dash, and I used an old metal clip (just super-glued to the back of the PDA mount) to serve as a hook for the cable, which I run behind the mount and under.
[attachmentid=794]
Besides filing down the plastic dive slate to fit the back of the mount clip, I also used the nail file to file down the plastic at the bottom of the PDA mount just a bit, because the opening was too narrow to accommodate the dock connector. Now it fits perfectly.
[attachmentid=795]
Sorry if the pics aren't more step-by-step, but I didn't think to take pictures while I was doing it. If anyone wants to try this, you can e-mail me; I can send a few more detailed pictures like of the back of the PDA mount, or the ratcheting arm (so you know which part to remove).
Sound quality is so much better with the direct connection; I also used an iTrip before, and it was decent outside the city, but got a lot of interference in the commercial areas. I don't use the equalizer settings on the head unit because they're not that great, opting instead to tweak the bass and treble, and then using EQ settings on the iPod.
File Type: jpg 04___Scosche_Eso34_ground_loop_isolator.jpg (8.3 KB, 69 views)
Old 10-04-2005, 10:59 PM   #5 (permalink)
Excellent
Seacam
