Use the insert image box which has IMG written on it. An address box will appear with http highlighted in blue, clear this and then copy and paste the URL address of your picture into the box, making sure it doesn't start with a double http address. If you want to add pictures into the garage section then just upload them as normal using the "browse" button to find them on your pc. An example to insert a picture would be
[ I M G ]
http://www.bbc.co.uk/crime/fighters/images/volvo195.jpg [/I MG] I have had to insert some spaces to confuse the command or else you would have just seen this as the example !
