Kia Rio rim sizes 2001-2012 ...rim contour designation/tire bead profiles - Kia Forum
post #1 of 11 (permalink) Old 02-20-2012, 12:17 AM Thread Starter
Drives: 2012 Rio LX sedan , 1995 ESCORT WAGON
Smile Kia Rio rim sizes 2001-2012 ...rim contour designation/tire bead profiles
Well I`ve got a new 2012 Rio lx. It has P185/R65/15 tires. The dealer wants like $100.00 CDN., plus for a black steel rims. So I asked them if the older model Rio`s rims would fit. They gave me not sure and a bunch of other dumb responses. So can anyone tell me if the rim sizes have gone up from 2010-2012 or even 2001 -2012 intotal? Also the tire contour designation is J. Actual manual says 5.5J x 15.It has 4 x100 bolt pattern. Hub and offset..I`m not sure. This confused alot of tire guys off in other shops I went to. It`s also called the Tire Bead Profile. If the rim sizes have changed then the wrecking yards won`t have what I need. The wheel size designation is probably written inside all the original owners manuals somewhere as it is in the 2012 Rio. So if anybody has some help on this one I`d be greatful.
Wheelnut is offline
post #2 of 11 (permalink) Old 02-20-2012, 09:04 PM
Kevster's Avatar
Drives: 05 Durango, 2012 Kia Soul+
All I know is my 2004 Rio had 5.5J X 14 inch rims. Not sure of the offset but they were also 4 X 100 bolt pattern. Seem to recall 32MM offset, back when I was considering chrome rims for it.
Kevster is offline
post #3 of 11 (permalink) Old 02-20-2012, 11:48 PM
Drives: 1994 Ford Aspire 1.3L (project car) || 1999 Mazda 626 (Daily Driver) || 2003 Chrysler Town & Country
I know the first generation Rio's had a 4x100 bolt pattern. That's what your looking for. There's also the offset and centerbore.
4x100 means 4 holes for bolts which are spaced 100mm apart, and most rims with this bolt pattern will bolt up to your hubs unless the centerbore size is smaller. If it's bigger it's not a big deal, you can get hubcentric rings to correct it if your lug nuts/bolts aren't tapered or acorn style to center the rims on the hub.
Google offset/centerbore/wheel spacer/hubcentric ring/acorn style-60 degree taper (lug bolts/nut shape) and when you figure out what these words mean you'll know enough to choose your own wheels.
If you go with a different size wheel and need new tires, this site has a nice tire size calculator you can use to determine what size tires you need to keep the speedometer right. You can compare up to 5 different tire sizes at a time!
Tire Size Calculator - tire & wheel plus sizing
zoom zoom is offline
post #4 of 11 (permalink) Old 02-22-2012, 04:29 PM
Drives: 12 RIO 5 SX, 07 VW Passat 2.0L turbo 1952 Siata Diana
Remember, there are negative and posative wheel offsets.
GALVYANK is offline
post #5 of 11 (permalink) Old 11-12-2014, 08:04 AM
Wheelnut, Just curious if you tried the older rims. I found 14 inch rims from a 2002 Rio, and want to make sure they will fit on my 2012 Rio. Thanks in advance!
Clueless1 is offline
post #6 of 11 (permalink) Old 11-12-2014, 05:49 PM
b18c5rodney's Avatar
Drives: '12 Kia Rio LX. '11 Toyota Tacoma, '07 Honda S2000, '11 Husaberg FS570, KTM 990 Adventure
Quoted: 18 Post(s)
Send a message via AIM to b18c5rodney
clueless, i am not exactly sure what you are asking. do you want a spare tire or a complete set of wheels?
but, if you want to know if 14's fit the 2012+ rio lx, then the answer is yes. i had 14x6 chinese steel wheels from tire rack on my 2012. the hub bore is 54.1 and the offset was +45. they were $41 each, plus shipping.
b18c5rodney is offline
post #7 of 11 (permalink) Old 11-13-2014, 06:52 AM
b18c5rodney, Thanks so much for the reply. I am looking to replace all my rims/tires. I currently have the 17" Stock Aluminum rims, and just want a cheaper tire/rim combination. To be exact, theses are the ones I am looking at: 175/65R14 Goodride Radial SP06
Thanks again!
post #8 of 11 (permalink) Old 11-13-2014, 10:09 AM
Drives: 14 Forte SX Koupe,15 Soul EX,58 & 90 Rolls Royces,92 Mercedes 500SL
Quoted: 27 Post(s)
@ Clueless1 . If you have the 17 inch Stock Rio wheels you must have an SX if you are in North America.BE CAREFUL as the SX has bigger front brakes & the dealer OEM is the Only steel wheel that will clear the brake calipers.
rroyce46 is offline
post #9 of 11 (permalink) Old 11-13-2014, 11:27 AM
rroyce46, Thanks for the clarification. I will avoid these rims. It's a shame, they were a decent price for all 4.
post #10 of 11 (permalink) Old 11-14-2014, 05:19 AM
Quoted: 18 Post(s)
rroyce is correct, if you have the larger 10" brakes, 14's will not clear. that link you posted, those tires are garbage, so be glad you did not buy them.
if you are looking for cheap steel wheels, you can get them in 15x6 for under 200$ new. i assume that you are in PA, and want snow tires?
  Kia Forum > KIA Models > Kia Rio Forum > 3G 2012+ Rio
