Hub conversion - Kia Forum
 2Likes
  • 1 Post By cgawelko
  • 1 Post By cobra259
post #1 of 9 (permalink) Old 02-13-2017, 06:31 PM Thread Starter
Drives: 2016 Kia Rio SX, 2013 Hyundai Elantra GT GLS
Hub conversion
Has anyone researched into, or actually done, a hub conversion from 4x100 to 5x114? I'm wondering if the Veloster or Forte hubs are the same.
BCkia12326 is offline
post #2 of 9 (permalink) Old 02-13-2017, 07:05 PM
sblake5's Avatar
Drives: 2014 Kia Rio, 2010 Mercedes Benz C300, 2005 Ponitiac GTO, 2017 Chevrolet Colorado 2WT
Quoted: 211 Post(s)
Have no knowledge on that but if it did work, you'd need more hardware than just the hubs.
2014 RIO LX: Ccruise control, SX console, Ford Taurus spoiler, 3" exhaust tip, K&N filter, dual horns, Proline 950S wheels, catch can, tint. Retired HVAC/MVAC tech.
sblake5 is online now
post #3 of 9 (permalink) Old 02-15-2017, 03:24 AM
cgawelko's Avatar
Drives: 2013 Kia Rio LX hatch, 1993 lexus LS400, 1989 toyota celsior, 2003 vw asspats, 2008 VW Eos
Quoted: 132 Post(s)
Yup. Most the time you need a full spindle. Depending on how the spindle is made, you may have to change a lot. Brakes may mount different, caliper mounting tabs could have different spacing, tie rods, control arms, even the splines in the hub could be different.
Rio:
cgawelko is offline
post #4 of 9 (permalink) Old 02-16-2017, 07:59 PM
Drives: 2009 RenaultSport Clio 197 R27
Quoted: 7 Post(s)
part numbers are all the same across Veloster/Rio/Optima/Sonata, so a 'big brake' upgrade is entirely plausible without major work
yianni_kdmss is offline
post #5 of 9 (permalink) Old 02-17-2017, 11:36 AM
cgawelko's Avatar
Quoted: 132 Post(s)
Part number for what? Because surely you cant be saying the hub assembly has the same part number considering the Rio is 4x100 while the others are 5 lug.
cobra259 likes this.
Rio:
cgawelko is offline
post #6 of 9 (permalink) Old 02-17-2017, 02:48 PM
cobra259's Avatar
Quoted: 364 Post(s)
Sorry, you are wrong about your statement. Hubs are not the same, no way they could be................
cgawelko likes this.
cobra259 is offline
post #7 of 9 (permalink) Old 02-17-2017, 03:58 PM
cgawelko's Avatar
Quoted: 132 Post(s)
he may be talking about the bearing itself being the same which means absolutely jack diddly. So lets go on his big brake upgrade is easy. So you press your hub out. Press in an Optima 5 lug hub. Now what does that have to do with caliper mounting? nothing. Brake lines? different. You would have to mount a rotor, measure height and spacing and then build a spacer - and then you can bolt the caliper. Then you have to worry about the lines. Now the calipers take more fluid to operate and the master will be insufficient. Then you have to upgrade the master and add in a proportion valve because the stock proportion block is setup for the baby calipers.
Rio:
cgawelko is offline
post #8 of 9 (permalink) Old 02-19-2017, 11:42 PM
Quoted: 7 Post(s)
nah guys, if you compare the part numbers for the hubs between the two, they're the same.
Here, proof. Knuckle and hub assy is the same.
Name:	Screen Shot 2017-02-20 at 4.41.22 PM.jpg
ID:	78514   Click image for larger version
Name:	Screen Shot 2017-02-20 at 4.41.28 PM.jpg
post #9 of 9 (permalink) Old 02-19-2017, 11:47 PM
Quoted: 7 Post(s)
And master cylinder/booster assembly, same part numbers.
Name:	Screen Shot 2017-02-20 at 4.44.33 PM.jpg
ID:	78530   Click image for larger version
Name:	Screen Shot 2017-02-20 at 4.46.10 PM.jpg
  Kia Forum > KIA Models > Kia Rio Forum > 3G 2012+ Rio
