Order the factory fog lights, order the factory switch. The factory wiring should be there for the fog lights you just have to plug them in(wiring kit may be needed, not sure on this SUV). change the switch for the one with fog light option your done (read on how to change the switch you don't want to break anything). Yes the fog lights will turn off when you put the brights on but it will be factory setup. I have done it before on a different vehicle it took about an hour.
