First Symptoms on my Sportage - Check Engine light on - Kia Forum
post #1 of 15 (permalink) Old 12-30-2010, 02:19 PM Thread Starter
Drives: Kia Sportage 2011 (EX-AWD) White
Default First Symptoms on my Sportage - Check Engine light on
Just to share the owner experience with everyone here...
Well, after driving for 3399 Miles (normal driving)... here come the first Symptoms. This morning when I start my car, the "Check Engine Light" turn on and don't go away. Check the fuel cap (ok).. restart the engine couple of times.. nothing suspicious... car just start like normal.. nor cracking or anything. Drove a few miles and still the "Check Engine light" on.
Deciding to bring it to dealer immediately... and reported the following after the diagnostic
"P0301 Code - Cylinder #1 Misfire"
Dealer found no problem and perform reset to clear the "Check Engine Light"
Well, since nothing found, the dealer would keep my car for a day and exchange for loaner if happened again
Will update again if this happened again.
Here is what I found from google
Technical Description
Cylinder #1 Misfire Detected
What does that mean?
A P0301 code means that the the car's computer has detected that one of the engine's cylinders is not firing properly. In this case it's cylinder #1.
Symptoms
Symptoms may include:
-the engine may be harder to start
-the engine may stumble / stumble, and/or hesitate
-other symptoms may also be present
Causes
A code P0301 may mean that one or more of the following has happened:
-Faulty spark plug or wire
-Faulty coil (pack)
-Faulty oxygen sensor(s)
-Faulty fuel injector
-Burned exhaust valve
-Faulty catalytic converter(s)
-Running out of fuel
-Poor compression
-Defective computer
Possible Solutions
If there are no symptoms, the simplest thing to do is to reset the code and see if it comes back.
If there are symptoms such as the engine is stumbling or hesitating, check all wiring and connectors that lead to the cylinders (i.e. spark plugs). Depending on how long the ignition components have been in the car, it may be a good idea to replace them as part of your regular maintenance schedule. I would suggest spark plugs, spark plug wires, distributor cap, and rotor (if applicable). Otherwise, check the coils (a.k.a. coil packs). In some cases, the catalytic converter has gone bad. If you smell rotten eggs in the exhaust, your cat converter needs to be replaced. I've also heard in other cases the problems were faulty fuel injectors.
radiowc is offline
post #2 of 15 (permalink) Old 12-30-2010, 03:15 PM
Drives: Sportage 2.0 EX
There's a service bulletin out about this problem. Its title is:
Combined TSB / Service action: SPORTAGE (SL) MIL ON
With DTC P0300~P0304 VCMA replacement (SA064)
If it happens again, you should talk with the dealer about doing the VCMA replacement.
lini is offline
post #3 of 15 (permalink) Old 12-30-2010, 03:47 PM Thread Starter
Thanks man! I will bring this to my dealer and have them replaced. ]
radiowc is offline
post #4 of 15 (permalink) Old 12-30-2010, 07:20 PM
The check engine light on my EX illuminated at less than 1000 km. The dealer replaced the coil on cylinder #1. I'm now at 5000 km with no further issues.
marshboy is offline
post #5 of 15 (permalink) Old 12-31-2010, 03:30 AM
Eyeball11's Avatar
Drives: 98 Honda CR-V, 08 GMC CC, 96 Camry Coupe V6, 11 Kia Sportage EX AWD
Thanks! Good information to have right there!
Eyeball11 is offline
post #6 of 15 (permalink) Old 01-13-2011, 08:55 PM
Drives: 2009 MiniCooper S, 2011 Kia Sportage EX LUX AWD
Gallery: 2
Unhappy 89 km's and the CHECK ENGINE LIGHT goes on?
Wow, I Knew this, all included in one Price, was too good to be true! You get what you pay for? What's next.....
I wonder if I can GIVE IT BACK, take my Toyota RAV4 back, it was 11 years old and had 97500 km and in the first 100km I knew it was a well built Toyota, NO I'd never buy ONE of them now, I'd be worrying if and when the Brakes would give, or the throttle would stick.
I'd better get more than, this is covered under warranty crap! BECAUSE I don't want it in the dealership LONGER than I have owned it.
Case in point, NEVER will buy another GM cause of my third one that was in the shop more in the first three months than me driving it around. I swore to GM and the dealer years ago, that I'd never touch GM for the rest of my life,.
The SPORTAGE EX LUXURY AWD is about my 14th NEW car, opps 15 now, I also drive a 2009 Mini Cooper S, It's not been to the SHOP and now pushing 9750 km.... It;s a FUN CAR to MOTOR around in, ONLY SUMMER driven,.
Any others wanna share their disappointment? Hurry let me know, I can still GIVE IT BACK.
SAGESteve is offline
post #7 of 15 (permalink) Old 01-14-2011, 12:49 PM
Drives: 04 M-B CLK500 Convertible and 11 Kia Sportage EX, leather and pano roof
8800 miles with no issues except the passenger wiper blade not clearing the windshield. They "adjusted" the arm and it seems to work ok...
kiagirl1256 is offline
post #8 of 15 (permalink) Old 01-14-2011, 01:22 PM
cobra259's Avatar
Quoted: 137 Post(s)
Let me get this right...you want to TRY to give your Kia back because....someone else has a check engine light on? Your Kia does not have any problems right? What do YOU have to be disappoined about????????
cobra259 is offline
post #9 of 15 (permalink) Old 01-14-2011, 02:33 PM
i m sick of this idiots...
adzo89 is offline
post #10 of 15 (permalink) Old 01-14-2011, 03:35 PM
cobra259's Avatar
Quoted: 137 Post(s)
What are you sick of?
cobra259 is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 3G 2011+ Sportage
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
