Top 3 gears of manual are quite close in ratio, so prepare to do a lot of shifting. Corresponding ratios of auto are more widely spaced as well as being (mostly) taller overall. Overall ratios of lowest 3 gears are about the same, so expect lower acceleration times to 100km/h for the auto, as is usual.
Cerato (Forte) transmissions and ratios are similar, and the manual is a little quicker to 100km/h as reported in various tests. However, you would need to punish the clutch to achieve this.
I'm very happy with the performance of KIA 6-speed autos. The car spends a lot of its time in 5th and 6th and returns good fuel economy because of the tall gearing. I think I would find rowing the manual along a bit of a chore, particlarly if you needed to change gears frequently just to maintain speed in everyday driving.
More powerful cars with 6-speed transmissions are less demanding. Adequate torque means that you can drive most places in 5th gear and only change gears when you want to really stir it along.
