kmay0417, do you drive the 1.4 Model EX Hatchback? Based from the Kiatechinfo.com, there is technical bulletin about SERVICE ACTION: INSPECTION FOR NOISE FROM ENGINE UNDER SPECIFIC CONDITIONS (SA 134) which says:
This bulletin provides information relating to certain RIO (U
2013MY vehicles which may
experience “rattling” or “chattering” engine noises under specific conditions. Only a very smallnumber of vehicles within the identified Production Date range will actually be affected; make sureto follow the detailed instructions in this bulletin to prevent unnecessary engine replacements.This procedure applies to vehicles produced from August 09, 2012 to October 09, 2012. Kia is requesting the completion of this Service Action on all affected vehicles in dealer stock prior todelivery. Before conducting the procedure, verify the vehicle is included in the list of affected VINs.
This is published by Kia America so you might want to check it out.
colin15, learning to live with it too! But still hoping that they find the right solution. If that rattling sound goes away, owners would be totally satisfied.
I've been figuring this since March. Not really an issue as confirmed by my dealer but an annoyance. After fueling with high octane gas, the noise still exists occasionally. The very recent updates I have is when few weeks back, I had it checked up with my dealer. A Korean Engineer confirmed that the sound is tolerable.
By now, I know when the sound will come out. The noise goes away when
1. Rev 2000 RPM
2. Make careful turns
3. Maintain a constant speed
