TPMS Warning light - Page 2 - Kia Forum
 1Likes
post #11 of 23 (permalink) Old 12-22-2012, 10:20 PM
Drives: 2013 Sportage EX AWD
Originally Posted by TechnoSX View Post
Wow you must never be wrong. You are correct I posted an assumption and readily admitted my mistake. You in turn decide to up your post count by adding a couple of meaningless posts to the thread to show everyone just how smart you are.....Merry Christmas
LMAO! Well put, and SO true!!! Merry Xmas
ChiTown2013 is offline
post #12 of 23 (permalink) Old 12-23-2012, 12:24 PM
Drives: 04 M-B CLK500 Convertible and 11 Kia Sportage EX, leather and pano roof
Now, boys! If you don't like a response, just ignore it. We're not here to increase our posts, but to provide information to our fellow forum members, even if it's wrong! ;^)
kiagirl1256 is offline
post #13 of 23 (permalink) Old 12-23-2012, 08:47 PM
Quoted: 54 Post(s)
Originally Posted by spongebob218 View Post
Recommended pressure is actually 33psi, cold. The TPMS system must see at least 33psi to clear the warning light. Try setting the pressure to 35psi in all the tires and see if the light goes out. Maybe your gauge is slightly off.
Also, does the light flash for a minute when you start the car up and then stay on, or does it come on solid initially. If it flashes first, it means there is a fault and a code is stored. If it doesn't flash, then it just indicates low tire pressure.
Great answer, particularly about a possible high-reading gauge combined with the mistake on the recommended pressure resulting in not enough pressure in the tire to turn off the warning.
OP, you thought cold weather MIGHT have affected pressure - it definitely does. You have to check your pressures weekly even when the low temps are about the same every night because all tires leak a little. When the low is 10 degrees lower than the previous low, you have to check them again.
Always check tire pressure first thing in the morning before the sun hits the tires.
2011 Sportage EX
FWD Auto Silver/Black
1saxman is offline
post #14 of 23 (permalink) Old 12-25-2012, 03:21 PM Thread Starter
HartUmp's Avatar
Drives: 2011 Sportage SX
Quoted: 4 Post(s)
OOpppps! I thought I read the recommeded PSI to be at 32 and I think I need a better tire pressure gauge. Thanks to anyone who actually took the time to reply with answer that would help solve the issue with the TPMS warning light.
HartUmp is offline
post #15 of 23 (permalink) Old 12-25-2012, 09:39 PM
Drives: 2012 Sportage EX
Also don't forget the spare, it has a sensor as well.
I am glad you mentioned this. Even though my Kia apparently does not have a TPMS, my other car might and now I know I should check there if this ever happens.
Also, when checking pressure, keep in mind the gauges can be way off. I have four guages and they are all different. The most expensive Accugauge one is off the most - I think...
Does anyone have any tips for calibrating a tire pressure guage?
michaelmfl is offline
post #16 of 23 (permalink) Old 10-10-2013, 01:03 PM
a light on my dash that looks like a horseshoe like figure and an exclaimation mark inside is lite up. I thought it was that the tire pressure was low, so I filled all tires. its still on. What does this mean?
schaef is offline
post #17 of 23 (permalink) Old 10-30-2014, 07:28 AM
i have a kia sportage. i bought it nov 2010. i think the name of the model is 2011. 1 month ago i just replace my tiers. the specific model comes with 225/60R17 hankook. my new tiers are 225/65R17. one month later the tpms light turns on. when i start the car is flashing and then stays on. i have the same pressure in all tiers. the low Tyre pressure position telltale is off. i was trying to increase and decrease the Tyre pressure in each Tyre to check in which on is the problem but nothing happened. the problem has to do with tyre size?? i must reset the sensor? how can i check if the sensor had broken ???
thank you very much
marios kia cyprus is offline
post #18 of 23 (permalink) Old 10-31-2014, 04:32 PM
Drives: 2016 Sorento LX AWD 2.4L w/ Convenience Package, 2014 Mitsubishi Outlander SE-AWC
Quoted: 78 Post(s)
It's not a good idea to replace the tires on your car with those of a different size.
You have bought a tire with a smaller sidewall. That means that your tire is not as big as the tire you replaced. So your speed readings will be incorrect.
You have some problem with one of the TPMS sensors. This is unrelated to your buying the incorrect tires, unless of course the inflation pressure of the new tires is not the same as that of the proper tires that you should have bought.
Why would you buy tires for your car that are not the correct size?
SoothingDave is online now
post #19 of 23 (permalink) Old 11-02-2014, 07:57 AM
i think 65 has bigger sidewall not smaller. about the tpms sensors. i believe that something need reprogramming or one of them has a problem. because i don't believe that broke when i change the tires and appear 1 month later. i took my car to an authorize mechanical and he told me that i must wait for the next time that he will have a kia with tpms sensor so to check my car with other car rims :/. to find which one has a problem!!!!!! i found that answer very stupid...... is anybody know how kia checki if the problem is on the sensors or if it is something with electrics....????????
post #20 of 23 (permalink) Old 11-04-2014, 07:37 PM
Quoted: 54 Post(s)
Mario; the first thing you have to do is to make sure you set the tire pressures at the value indicated on the sticker on the door jamb or body, visible when the driver's door is open. Always set tire pressures when the tires are dead cold, like early in the morning before the sun hits them. Don't forget about the spare tire - set it at the recommended pressure you find on the side of the tire.
Then, monitor the tire pressure every few days early in the morning before driving the car to see if any of them are leaking. You could have a tire with a nail in it that's causing a very slow leak. It could also be a slow leak at a valve stem. I don't know how long the batteries last in a TPMS, but since I also have a 2011, I guess we'll find out.
2011 Sportage EX
1saxman is offline
