Rear Window Washer - Kia Forum
post #1 of 14 (permalink) Old 08-21-2011, 12:53 AM Thread Starter
Drives: 2012 Sportage LX
Send a message via AIM to donniekl
Rear Window Washer
I notice with my rear window washer (yes, I actually use it) that it doesn't really spray fluid on my back window. It just trickles in a stream right down the middle of the window. Yes, its functional as it is, but I just bought something brand new and I expect everything to work perfectly.
Do all of the rear washers perform how I described? I would expect it to spray in a fan pattern similar to the front.
Thanks for your help!
2012 Kia Sportage LX, 2.4L AWD Signal Red
Interior, reverse, plate LED lights; 55w 6000k HIDs w/ harness, 5000k highs w/ harness, chrome signal bulbs, dual horn upgrade SEARCH FIRST, THEN POST!
donniekl is offline
post #2 of 14 (permalink) Old 08-21-2011, 01:28 AM
Never tryed mine. I'll let you know how it does.
LT4Bird is offline
post #3 of 14 (permalink) Old 08-21-2011, 07:22 AM
same here.
don't worry it's working perfectly
zero0 is offline
post #4 of 14 (permalink) Old 08-21-2011, 07:39 AM
Drives: 2011 Sportage SX
Quoted: 30 Post(s)
On my previous cars the rear windows washer never sprayed like how the front washers spray, they just sent a stream of fluid down the middle of the glass.
It's normal.
bluntman is offline
post #5 of 14 (permalink) Old 08-21-2011, 11:08 AM
KenP's Avatar
Drives: 2017 Sportage SX AWD, 2011 Sportage SX, 2016 Range Rover Sport HSE
Quoted: 11 Post(s)
Mine too, just flows down the middle of the window.
KenP is offline
post #6 of 14 (permalink) Old 08-21-2011, 01:37 PM Thread Starter
Thanks all! Saved me a trip to the dealer.
donniekl is offline
post #7 of 14 (permalink) Old 08-27-2011, 11:40 PM
Drives: 2011 Kia Sportage LX
Same here on my Sportage ... also works the same way on my Toyota Matrix. Probably because of the unpredictable airflow at the rear of the car - a spray may or may not reliably get on the glass depending on how fast you were going.
As was said earlier... functional
dmann is offline
post #8 of 14 (permalink) Old 10-19-2011, 06:00 AM
How to Replace Rear Window?
Replacing rear windows is not much different than replacing front ones. It also might not happen as often since most damage often occurs to the front windows. More than anything, make sure that any replacement window glass is not just for your make and model vehicle but also designed for the rear door and not the front. The two major causes for window replacement lie in the glass itself and the regulator holding it within the door.
1. Access the Window.
2.Replace the Window.
You have to be careful of them .
CleanWasher is offline
post #9 of 14 (permalink) Old 10-19-2011, 09:20 AM
cloud9utk's Avatar
Drives: 2012 Sportage SX FWD
same on my 2012 sx. was the same on a 2009 honda fit sport, and the same on a 2001 hyundai elantra gt (fastback)
2012 Kia Sportage SX FWD, Silver, Leather, UVO, keyless entry.
no sunroof, no nav, no interior led lighting, no heated/cooled seats.
19/25/32 mpg
cloud9utk is offline
post #10 of 14 (permalink) Old 10-20-2011, 07:13 AM
Drives: VW Polo 2008/ KIA Sportage 2012 2.0 CRDi 4WD Exclusive
Actually it is not possible to have a spray on the back window. at regular driving speeds, there forms a kind of suction effect on the back window due to the aerodynamics of cars/ hatchbacks mainly. you need a powerful jet to overcome the force otherwise if there was a spray you would just get the window washing liquid in thin air, while driving. then it wouldnt be working perfectly since you would have to nearly stop the car to wash the rear window.
Kaivish is offline
