Solar glass? - Kia Forum
post #1 of 7 (permalink) Old 03-26-2011, 09:56 AM Thread Starter
Drives: 2011 Sportage LX
Solar glass?
Can anyone explain this to me? I tried to look it up on google but no luck.
Muppetz3 is offline
post #2 of 7 (permalink) Old 03-26-2011, 11:41 AM
Bowie97's Avatar
Drives: kia
Gallery: 34
Where dit you see it? Would be helpful.
The context of a word or words in a sentence can be better explained as the whole sentence is also visible.
Or where the word is used.
It could be anything
Solar panel, Sunglasses, Sunroof, Solar panel glass.
Sharing experiences is one of the goals of a forum, which is my idea of a forum.
There are no stupid questions, but anyone can give a
answer.
Bowie97
Bowie97 is offline
post #3 of 7 (permalink) Old 03-26-2011, 12:32 PM Thread Starter
On my window sticker, it is part of the convenince package. Just says "Solar Glass"
Muppetz3 is offline
post #4 of 7 (permalink) Old 03-26-2011, 12:38 PM
Drives: 2017 Kia Niro Touring w/Tech Pkg
Quoted: 21 Post(s)
This is a Sportage Forum so it would be concerning a Sportage and it is mentioned as part of the LX convenience pkg in the USA.
Solar Glass is a Solar energy or UV reduction glass that blocks (much or all) of the ultraviolet and infrared rays.
njerald is offline
post #5 of 7 (permalink) Old 03-26-2011, 02:44 PM
junrider's Avatar
Drives: 2011 AWD Sportage SX
I read this on the kia optima description of solar glass:
"Solar glass is equipped to keep you and your passengers cool and comfortable as you relax onboard"
junrider is offline
post #6 of 7 (permalink) Old 03-27-2011, 08:09 AM
Bowie97's Avatar
Drives: kia
Gallery: 34
So you see with a little bit of help from yourself and the answer is given by Njerdal and Junrider.
By the way, make your profile as complete as possible, indicate where you come from and what car you have.
answer.
Bowie97
Bowie97 is offline
post #7 of 7 (permalink) Old 03-27-2011, 05:39 PM
imay's Avatar
Drives: Kia Sportage Platinum diesel and Rio 3 door SLS
Gallery: 4
Quoted: 15 Post(s)
My understanding (or interpretation) of Solar Glass would be that it has been treated to exclude a high(er) percentage of UV - the factor that causes sunburn, premature ageing and fading of fabrics/upholstery, etc.
The "tinted" windows many modern cars come standard with these days is usually merely colored glass which may help reduce the sun glare factor but does not significantly reduce the UV penetration into the interior. Thereby the sun is still hot against the skin with the windows up.
I have just had UV film put on my Sportage - even the "tinted" rear windows - and it has made a significant difference. Easy way to distinguish solar glass is to drive with the window down on a hot sunny day and feel the effect of the sun on your skin, then put up the window. No significant reduction in the "burning" effect would indicate that the windows have a colored tint factor only.
Some car brands are now coming out with "solar" windscreens. There is a UV and anti-glare factor built into the front glass. This significant reduces heat entering through the front window. However it also can have a signal reducing effect on sat-nav and audio systems with an internal aerial, or the aerial built into the glass. An added external aerial is the easiest solution to this problem.
As a side note: DON'T apply any tint film (UV or other) to the sunroof glass as this is tempered glass and is designed to expand and contract according to heat upon it. Film will bubble, blister and crack over time, rendering it ugly and useless.
Old enough to know better . . . . too old to care!
imay is offline
