I purchased on Ali express about $38 shipping include. Just need join 3 wires. Unlock signal, lock signal and a constant +12v. The hard part of instalation is pass the cable to the cabine to get 12v.
Still waiting to receive from ali, Can't wait to install. I'm probably not going to install the remote 2x lock= close allwindow, 2xunlock= open all window option though.
Bummer, after waiting 41 days to receive. I got the door panel off and realized the plugs are different. Not really wanting to cut and splice all those wires so I contacted the seller waiting for them to get back
Well I can't believe it but I finally have both front windows one touch auto up down. A little bit of a let down that the rear windows can only be auto opened or closed one at a time but none the less I'm very happy with this mod.
Uh perhaps some one could help with a translation of this translation, the seller sent me when I asked him about the 2 rear windows not being able to do one touch auto up down at the same time.
"you need to hold the button until the glass go the topest for 6-10s, then hold the button until the glass go the underest for 6-10s"
This is an option I am debating on my 15, along with sunroof. I will use the Viper 535T only because I seen a lot of burnt out motors when I used to install professionally. I would never buy anything aliexpress or ali-baba as it is usually cheap in quality. I hope you the best with this and may it be trouble free, but professional experience will tell me otherwise. I personally am victim to this back in the day (96ish) with a Code-Alarm window module
I usually just pin the Molex plugs with the correct inserts as if it were factory. That way if the harness has to be disconnected, it can be disconnected.
I forgot to mention that the 535T have built in limit switches so if a kid sticks their neck out the window (or a pet) the module will stop without decapitating or strangling them, any obstructions will stop them. My dilemma is that I want to have one touch from every switch so, the wiring will be immense. I will also do the sunroof, but I believe I will just power that circuit up via a custom made circuit and call it a day. Everything is hooked up to the Viper system. I wrote an article on the new system that should be available to the public within the next few months.
