I've searched everywhere and can't find an answer to my problem. I'm hoping someone here might be able to help.
I have a 2011 sportage with 85000 miles. The other day it rained very hard, that's when the trouble started. I'm not sure if it's just a coincidence though.
first, on the day it rained, we drove somewhere, parked it, and when we came out, it wouldn't start.
electronics on, turn the key and nothing. No crank, no solenoid sound, nothing. I tried shifting it into neutral, repeatedly pressing the brake, e-brake... then suddenly it just started back up, and we drove home.
The next day I drove the car again. This time it died while driving, and I had to pull over. Eventually it started back up, died again, started up, died again, and I got it home that way having it die one last time before coasting to the front of my house.
I tried to diagnose the problem then. There is no check engine light, and no codes. If i turn the key to ignition and leave it there, initially i hear no relays and no fuel pump. Then, while still turned to ignition, the relays will click and the fuel pump will turn on, then turn off again, and back on, and off again seamingly at random.
Then sometimes, I can walk out and it will start right up no problem. When it starts up, I get down under the dash and push and pull all the wires and all the plugs, and i get the problem to replicate.
Does anyone have any idea what it could be?
