Constant-RED
Ignition-GREEN
Ground-BLACK
You won't need the illumination wire for an aftermarket deck.
There's actually two black wires, both go to ground, so you may as well use both; just twist them together when hooking them up to the deck.
Battery power and Continuous power is the same thing. There are no standards for car companies to make wire colors the same, but there is a standard for the aftermarket companies. (aftermarket, yellow is always constant, red is always ignition, blue is always amp turn on/power antenna, etc..)
