Help! Check Engine / Transmission code p0741 - Kia Forum
post #1 of 7 (permalink) Old 11-30-2010, 04:58 PM Thread Starter
Drives: 2006.5 Kia Optima LX
Hello everyone!
I recently bought a used 2006.5 Kia optima, 2.4L 4 cylinder with an automatic transmission. Currently has 93,000 miles.
2 days ago I drove from Ma to Va about 650 miles. Drove excellent and had to be getting at least 30 mpg. No problems in the drive train whatsoever.
But this morning, after about 5 minutes of driving, I was approaching a stop light and the car started to shudder as if it were about to stall out (felt just like a standard transmission car would if you went to stop with it engaged in gear and the clutch out - shuddering and RPM drop)
The light turned green before I had to stop complete, and it took off fine. Never did it again.
Brought it by Autozone and had a code P0741
Torque converter stuck off
--Probable causes:
-open or short circuit condition
-poor electrical connection
-faulty torque converter solenoid
I checked the fluid, it was full. It is a brownish color that it was before I drove across the country. I don't think it is burnt but due to be changed - fluid and filter are original to the car from the factory. Service says to change at 100 or 102k miles but I like to do it sooner to help the trans live longer, but have only had the car about 2 weeks.
Only happened once, has been perfect before and after. Goes right into gear, hot or cold, shifts perfectly smooth, plenty of power, good gas mileage, ect.
Could this just be a fluke or sign of something to come? I'd like to check into some things before having to head back home in a few days (650 miles) for a bit of self assurance.
A lot of the mileage on this car are highway, it has been back and forth from Mass to Florida several times, I bought it from the original owner whom I've known for several years.
Maybe someone else has dealt with this?
Thank you all for any input!
xeauto2010 is offline
post #2 of 7 (permalink) Old 11-30-2010, 11:19 PM
Pacosworld's Avatar
Quoted: 13 Post(s)
Originally Posted by xeauto2010 View Post
Hello everyone!
--Probable causes:
P0741 Torque Converter Clutch Stuck Off
Possible Cause
● Faulty TCC or oil pressure system
● Faulty TCC solenoid valve
● Faulty body control valve
● Faulty PCM/TCM
I would change the ATF just as a precaution. You might also check that the transmission electrical connector is clean and seated completely. If it occurs again or starts to occur on a regular basis, you might get it checked out by a Kia dealer.
Mike AKA Paco
Pacosworld is offline
post #3 of 7 (permalink) Old 12-02-2010, 08:08 PM
Drives: 2008 Kia Optima
Quoted: 43 Post(s)
I'd look at the solenoid. If the converter doesn't unlock, find the solenoid and disconnect it until it can be fixed. Not great to ride around without the converter locking up as it will generate more heat.
turbonut is offline
post #4 of 7 (permalink) Old 12-06-2010, 02:28 PM Thread Starter
Thanks for the advice.
I have since returned home and put another 1,000 miles -/+ on it, never acted up since.
Been meaning to swing by the dealer to ask them their opinion but time has yet to allow that.
I also had the CEL re scanned and the code is gone, it must have reset itself since it hasn't happened ?
I will be changing the fluid and filter soon. They say its a spin on filter similar to an oil filter (a Galant and XG300 I owned both used that type)
Should anything special be added to the fluid? Autozone says to use Multi import ATF. Id like to do things right the first time, esp when it comes to the fluid.
Not sure if I can disable the solenoid it might be an internal part.
Thanks again =)
post #5 of 7 (permalink) Old 12-31-2010, 11:36 PM
You need to change your "oil control valve". This problem has happened to a few of us on these forums as well as on the 2.4L Theta-equipped Hyundai Sonata.
quickfingerz is offline
post #6 of 7 (permalink) Old 10-21-2011, 12:31 PM
Drives: 2005 Blue Kia Spectra5 and a 96 Turbo Honda civic and a 99 subaru outback with a 2.5 rs turbo motor
Gallery: 10
Quoted: 5 Post(s)
Send a message via Yahoo to tt2jzgtes Send a message via Skype™ to tt2jzgtes
where is the oil control vavle? i dont kno if its the same on a 05 kia spectra5?
tt2jzgtes is offline
post #7 of 7 (permalink) Old 10-19-2012, 09:24 AM
Quoted: 20 Post(s)
Hello everyone!
Code P0741
--Probable causes:
Been right at 2yrs .....
What ended up being the problem?
What was the SOLUTION?
WeAreNotAlone is offline
