5w30 vs. 10w30 oil? - Kia Forum
post #1 of 9 (permalink) Old 05-13-2009, 12:08 AM Thread Starter
palebeachbum's Avatar
Drives: 2006.5 Kia Optima LX 2.4L 4cyl 5-spd man.
Gallery: 5
5w30 vs. 10w30 oil?
I'm not sure what viscosity oil is best for my 3G Optima's 2.4L 4cyl. The oil cap has 5w20 printed on it, but that seems awfully thin for summer temps. So I checked the owners manual and it states 5w20, 5w30, or 10w30 are fine for my temp. range. What do you guys recommend I use for best engine longevity and performance?
Also, my 4cyl. makes a clatter noise below 2,000rpm. It sounded ugly, so I had them put in 10w30 at my last oil change. It didn't help at all. Is this clatter at low rpm normal for the 4cyl? I asked my Dad about it and he said some engines clatter like that at low rpms because the compression is low at low rpms, but dissapears as rpms and compression increases. I may have misunderstood a little, or is this correct?
palebeachbum is offline
post #2 of 9 (permalink) Old 05-13-2009, 05:33 AM
Drives: 2008 Kia Optima
Quoted: 44 Post(s)
You can use 10-30, but I'd stick with the 5-20 or 5-30 and you'll have no problems. Technically, the 10-30 and 5-30 will have the same viscosity when hot. The oils and tolerances are much different than they were years ago, so the manufacturer's recommendations have changed quite a bit. When using the recommended oil it will afford the best fuel mileage and lubrication.
No unusual engine noise here.
turbonut is offline
post #3 of 9 (permalink) Old 05-13-2009, 08:10 AM
cmhj2000's Avatar
Drives: 09 Cobalt
5W-20 is fine. It's usually better to stick with speced viscosity for most engines and more so those with VVT.
cmhj2000 is offline
post #4 of 9 (permalink) Old 05-13-2009, 12:23 PM
PLP
PLP's Avatar
Quoted: 318 Post(s)
Hello,
first, add info to your profile - location especially, so we wil be able to discuss the oil problem in more details
next thing, what is the mileage?
and just quick explanation:
5W20 - in general XX W YY
XX stands for high temperature viscosity, the lower the number, the lwoer the viscosity, the thinner the oil film, the better fuel economy
YY stands for low temp properties. Higher number means higher viscosity, so the lower temperature, the more energy needed to pump the oil. For example 20W50 will have high viscosity at 100C what means, old engine will perform quieter, but at low temp (below -10C, 10F) will be very hard to pump. It will look like honey.
USA - paid, repair manual
Europe - paid, repair manual
PLP is offline
post #5 of 9 (permalink) Old 05-16-2009, 01:48 AM
Even on cars that "required" 5w-20 oil, there was consistently more wear when a 5w-20 oil was used than when a 5w-30 oil was used. This has been tested many times.
I typically use 5w-30 year round. 5w-20 oil has been specified for many cars to meet CAFE standards.
quickfingerz is offline
post #6 of 9 (permalink) Old 11-06-2010, 10:05 PM
been using 10w30 as recommended by the authorised service centre here in malaysia
a mechamic friend of mine surprised of such a thin oil for 2.0l car
he said only small car (small engine displacement, eg 1 litre) uses 30 oil
while 1.6L / 2.0L car requires thicker oil, ie 40 or 50
the other car of mine which is 1.6L uses 10w40 as stated in the manual
how true is it ?
PuPPy is offline
post #7 of 9 (permalink) Old 11-09-2010, 03:38 PM
stuartadair's Avatar
Drives: 08 Magentis 2.7, 08 Citroen C1, 88 Yamaha ZR750, Kinroad 50, Yuen 125-23
....but that seems awfully thin for summer temps.
For those of us who live in a proper hemesphere its winter right now, and damn cold. Nice thin oil is the order of the day
stuartadair is offline
post #8 of 9 (permalink) Old 02-02-2011, 07:03 PM
Drives: Couple optima's for now.
Lightbulb How to decode oil labels.
I have a minor correction to the information you've posted.
XX= the weight/viscosity of the oil when cold, measured at 0 F
W= winter grade
YY= the weight/viscosity of the oil when the engine is at operating temperature. measured at 210 F.
so a multi viscosity oil of 5W30 flows like a 5 weight oil when cold yet will act like a 30 weight at operating temperature.
Reference List:
What Every Motorist Should Know About Motor Oil
Motor Oil Viscosity Grades Explained in Layman's Terms
What do oil viscosity numbers mean? Learn about motor oil, synthetic and regular.
Motor oil - Wikipedia, the free encyclopedia
Gear oils are rated differently so a 70w130 gear oil is not a 70 weight at 0 F and 130 weight at 210 F.
Wrench is offline
post #9 of 9 (permalink) Old 02-08-2011, 03:43 PM
Oh and I forgot to add...if you had a proper engine it wouldnt rattle at all
