Recomended Spark Plug - Kia Forum
post #1 of 12 (permalink) Old 09-16-2012, 10:29 PM Thread Starter
Drives: 2010 KIA Rio LX Midnight Black.. CAI.. 6000k HID..
I am changing the plugs on my '10 LX and trying to see what are the best type for the engine. I only use synthetic oil, looking for the best gas mileage. Or performance, whichever are best for my car!
Bmak18 is offline
post #2 of 12 (permalink) Old 09-16-2012, 10:57 PM
Quoted: 10 Post(s)
Whenever I change plugs on Rios, I use NGKs, part# 2382. They are just a standard resistor plug, which is what all those Rios came with from the factory. I believe they cost around $2 each, maybe even less.
There are platinum and iridium plugs available, but you could change the standard plugs multiple times for the same price. Platinum and iridium plugs will last longer, and possibly provide a very slight performance increase(noticeable???), but cost more. If you decide to go with these, I'd go with NGKs, or Densos if available. I'd stay away from Autolites, as I have seen them break off ground electrodes and cause engine damage.
spongebob218 is offline
post #3 of 12 (permalink) Old 09-17-2012, 05:34 AM
Drives: 06 Rio, 136K miles
+1 on the NGK 2382
06Rio_FW is offline
post #4 of 12 (permalink) Old 09-17-2012, 08:30 PM Thread Starter
ive always used bosch +2's on my vehicles and they work wonders. ?
Bmak18 is offline
post #5 of 12 (permalink) Old 12-05-2012, 02:50 PM
Drives: 2007 Rio5 M/T
Using Bosch +2 on my '07 Rio5 with no issues.
ssency is offline
post #6 of 12 (permalink) Old 12-05-2012, 05:17 PM Thread Starter
any mileage difference?
Bmak18 is offline
post #7 of 12 (permalink) Old 07-05-2013, 07:06 PM
Drives: Kia Rio5 2010
I have to buy some plugs for my 2010 rio,still debating on what spark plugs to get standard NGK or some bosh platinum...Please help me decide
goldenboy is offline
post #8 of 12 (permalink) Old 07-13-2013, 06:32 PM
Drives: 2009 Rio5 :)
Standard plugs unless you have upgraded you ignition, or grounding system, along with better wires....
Sorry. They really market to us so much. Our electrical systems are not meant for these Platinum 4's or what ever kick butt $6 - $8 plug they are selling right now.
Use regular copper plugs, your choice as to brand. Use a loop for gapping, not that disk thing, and you really shouldn't have to worry about them for 60 to 100 thousand miles.
Well... That's my two cents. Hope it helps.
teckis2000 is offline
post #9 of 12 (permalink) Old 07-14-2013, 05:26 AM
Drives: Cerato S Hatch Auto
Quoted: 3 Post(s)
Originally Posted by teckis2000 View Post
Standard plugs unless you have upgraded you ignition, or grounding system, along with better wires. Our electrical systems are not meant for these Platinum 4's or what ever kick butt $6 - $8 plug they are selling right now.
Not sure where you're coming from with this idea. The ignition system just makes a spark and this has nothing to do with the type of electrode. Electrode type influences longevity more than anything else. It's usually only the centre electrode that is made of exotic metal. Heat rating of the plug is determined by insulator length and design the of centre terminal. Correct installation is also important.
Wry 'Cuda is offline
post #10 of 12 (permalink) Old 07-14-2013, 06:24 AM
OK Cuda,
You get a +1 for that.
Here are the brass tacks though. Do you have a high performance engine? High compression? Low compression with boost? Aftermarket ignition system? Do you have to run a different gap on your plugs? This is what you would need a smaller filament, or iridium for.
(PS they do have to put a resister in plat, gold and silver plugs because of the skinny filament)
You will also not notice a gain in HP or MPG unless your current plugs are just horrible. I would go with the NKG's so +1 for the 2382's.
Easiest way for quick and easy MPG and MPG are Cold Air Intake, and Freer Exhaust.
Best of Luck!!
