How to change spark plugs... - Kia Forum
post #1 of 3 (permalink) Old 12-30-2007, 01:45 PM Thread Starter
Drives: Kia Rio5 2010
Hi
I was looking under the hood of my Kia Rio 2006 and couldn't see the spark plugs so i took off the plastic cap that cover the motor and i see 4 connector but it doesn't look like spark plugs can somebody tell me how to change them and where they are? is there a mechanic manual i can download. thanks
P.S Somebody told me that the air filter in the Rio is very long lasting and should be good for a very long period,is that true?
goldenboy is offline
post #2 of 3 (permalink) Old 12-30-2007, 02:50 PM
Drives: 1999 Kia Elan
Quoted: 383 Post(s)
I don't have any experience on this engine, but I guess You need to take the cover off the center of the camshaft cover.
Take a look at this site and you may find more info - it doesn't have the 2006 listed but it may be similar to the 2005.
http://www.kiatechinfo.com/viewer/de...asp?group=shop
ron1004 is offline
post #3 of 3 (permalink) Old 12-30-2007, 05:48 PM
Drives: 06 Rio LX
Lets see if I can make this work Global Service Way
If you took the plastic cover off, then use your 10mm socket to remove the 3 bolts holding the wiring that runs over the #4 plug and use the same 10mm socket to remove the coil hold down bolts. The Rio uses a coil on plug system so you have 4 coils over each plug.
The Rio air filter is nothing special change it when you would change any other air filter. I changed mine at 25k.
RDNK 4RE is offline
