Here's the kicker; a member on here had posted the code involving pushing the recycle button 5 times to shut off the a/c.
Does not work in my '09; even tho the actual a/c button is in the off position the pump will still run in the defrost settings and the led on the a/c button still lights up in the off position. I do understand that it does help in clearing off a frosted or iced up windshield but i want to have 100% control of it. This should not function unless you turn on the a/c button yourself.
This car has an excellent heating system and will cook you so i want to have it shut off in the winter to avoid any wear and tear on a very expensive pump.
Is there another code for this or does the mentioned code only work on the 1st gen of rios? If there's no code or anyone else finding this issue annoying i can always just unplug the a/c pump and plug it back in for the warmer weather. Thoughts and suggestions are appreciated, thanks.
