Changing Tire Sizes - Kia Forum
post #1 of 6 (permalink) Old 09-09-2010, 03:10 AM Thread Starter
Drives: 2007 Kia Sportage 2.7L V6, 2000 Ford Focus SE 2.0L DOHC Zetek, 2000 Dodge Neon
Default Changing Tire Sizes
I'm considering purchasing a set of General Grabber UHP tires for my 2007 Sporty 2.7l. The stock tires, as we all know, are 235/60R16, but the closest I can get with the UHPs is 235/70R16. I've run a conversion calculator and discovered that the UHPs would be 1.9 inches taller than the stock tires, and I know that changing tire size will affect performance as well as louse up ABS sensors and ESP as well as the speedo accuracy.
Has anyone else moved up in tire size on their Kia? If so, how much bigger did you go, and what changes did you have to make to compensate. Is 1.9 inches going to be that much of a difference? It sure doesn't seem like much change. The stock tires pull 744.15 revs per mile, whereas the UHPs would have 696.59 revs per mile.
JackofGreen is offline
post #2 of 6 (permalink) Old 09-09-2010, 05:42 PM
The 3 tire sizes that the Sportage came with:
235/55/17
215/65/16
235/60/16
I wouldn't go more than 1" taller on the tire without taking measurements. I expect them to rub especially on turns. You'll probably need spring spacers or a mild lift kit to fit those tires that are 2" taller.
Besides the stock sizes, other sizes to consider:
215/70/16
225/65/16
Pick a different tire.
deadrx7conv is offline
post #3 of 6 (permalink) Old 09-10-2010, 03:52 PM
1fastkia's Avatar
Drives: 08 Sportage, 87 Mazda RX-7
Quoted: 5 Post(s)
235/55/17
215/65/16
235/60/16
215/70/16
225/65/16
My sportage came with 205/65/16. Its the lx 4cyl. I went up to 225/60/16 with no issues. The 205's just looked odd on the sportage.
08 Kia Sportage
07 Saturn Aura
87 Mazda RX-7
Working on a 07 RX-8
The Old
99 Sephia, 01 Spectra, 05 Spectra
1fastkia is offline
post #4 of 6 (permalink) Old 09-14-2010, 05:53 PM
225/60/16 is smaller than what was stock and smaller than what the thread starter already has. The speedometer, which is optimistic, will be even MORE optimistic with that size.
I know that I want a little taller too and listed what I will be trying once my tires wear down.
Check your doorjam sticker or owners manual. 205 width isn't an OE size in my 2008 owners manual page 8-4.
post #5 of 6 (permalink) Old 09-17-2010, 03:11 PM Thread Starter
So, after a full nights sleep and a pot of coffee, I double-checked the General Tire website and discovered they DO make the Grabber UHP in the 235/60R16 size. So it's all good, I can stick with the stock size and still get the tires I want.
Thanks for your posts though, I appreciate it.
post #6 of 6 (permalink) Old 09-21-2010, 05:35 AM
1fastkia's Avatar
Quoted: 5 Post(s)
I'm almost positive it had 205s on it but I will double check, I have the tires in my garage. They were the tires that were on it when I bought it with 3 miles on it, so they were from the factory. I do know the speedo is not off due to speed trailers that show your speed on them around town. They throw these up around here to show your speed. They are all over vermont in summer months.
And Ill double check the size I went up to. Ill post it up later.
08 Kia Sportage
07 Saturn Aura
87 Mazda RX-7
The Old
1fastkia is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 2G (2005-2010) Sportage
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
