Automatic Transmission fluid change - Kia Forum
post #1 of 2 (permalink) Old 01-13-2010, 11:52 AM Thread Starter
Default Automatic Transmission fluid change
The first step in the instructions from Kia Tech is to "disconnect the hose, which connects the transmission and the oil cooler. . ." This is on a 2.7L so the transmission coooler is seperate. The second step is to star tthe engine and let the fluid drain out.
Problem is there are 2 hoses. Does anyone know which one to disconnect and how you would identify it?
I know that I could just remove the drain plug and let the fluid out, but that would only change 1/2 of the fluid. I'd prefer to totally change it now and not have to worry about it for a while.
Gavin
dinghyboy is offline
post #2 of 2 (permalink) Old 01-18-2010, 01:03 PM
Trial and error.
Use the drainplug.
Disconnect the hose just pumps the pan dry. Removing the drainplug drains the pan dry. No difference!
Disconnecting the hose method requires you to stop, refill, and restart, to truly pump out all the fluid using a gross amount of ATF(capacity + several quarts more).
deadrx7conv is offline
  Kia Forum > KIA Models > Kia Sportage Forum > 2G (2005-2010) Sportage
Quick Reply
Message:
Options
Register Now
Password
Confirm Password:
Email Address
Email Address:
Log-in
Human Verification
You may post new threads
You may post replies
