Help my Sportage EX 2005 model stops. Engine starts fine but stops after 15sec. When running an OBD scanner shows the code P1187. What does the code. what could it be? can anyone help?
Where can i find the Regulator Valve in my Kia Sportage 2005 mod.
is there a exsplodert picture of injection in a Kia Sportage 2005 showing the Regulator Valve in my Kia Sportage 2005 mod?
regulator valve
I ask because my OBD says error code P1187 and the only explanation I have found the error code is: regulator valve - stuck. I have a 2005 Sportage EX 2.0 DOHC have any idea what it could be and where can I find it any stuck regulator valve? very bad explanation but I need good suggestions.
After 3-4 attempts to start the car loosened the error and it was possible to drive it home.
Filled purified kerosene into the fuel tank and hope it "lubricates" the valve so it does not happen again soon.
