Radio Not Working - Kia Forum
post #1 of 6 (permalink) Old 02-05-2013, 09:21 AM Thread Starter
darnell89's Avatar
Drives: 2007 Kia Sportage LX 4WD (M/T)
Send a message via AIM to darnell89 Send a message via Yahoo to darnell89 Send a message via Skype™ to darnell89
Angry Radio Not Working
Jumped my Sportage, and now the radio isn't working. How do I get it to work? Does Kia radios require a code like Honda? It won't power on or anything. Replaced Fuses (Audio, Start, and Room Fuses). Is there a fuse to the power connector to the radio, that might of went out?
Future Kia/Hyundai Vehicles: Kia Borrego Limited 4WD, Kia Sorento SX, or Hyundai Genesis 3.8
darnell89 is offline
post #2 of 6 (permalink) Old 08-28-2013, 01:43 PM
lpb
Same problem, and I note the lack of responses. The problem is not the 10amp fuse; did you ever get yours working again?
lpb is offline
post #3 of 6 (permalink) Old 12-03-2013, 10:23 PM
Hi,
I was installing a Sony head unit and now I have the same issue.. 0 volts in the positive wire from the original radio connector.
Is there something that we can do to solve this? The fuse is OK and it's receiving 12 volts.
I'm thinking to get the positive from other source such the switch or the acc 12 volts.
Aussierey is offline
post #4 of 6 (permalink) Old 12-06-2013, 12:05 AM
tysinbad's Avatar
Drives: 06 Sportage/2012 Navara V6 TD
Quoted: 6 Post(s)
The stock head unit also has a fuze in the back of the actual unit. At least mine does - model Cadence ZCD-6704A.
If you can measure 12 volts on both sides of the various fuzes, then the problem is obviously not there. Power to the plug will that goes into the head unit will confirm the wiring is OK.
Attached is a copy of the wire diagram from www.kiatechinfo.com. There are actuallt three diagrams dependant upon the number of speakers/sub if you have it, but the diagram is essentially the same.
Hope this helps.
06 V6 EXL Sportage - NGM Stage 1 Sniper Charged
UNICHIP ECU, 2.5" Exhaust, Custom Headers, Modified Intake
tysinbad is offline
post #5 of 6 (permalink) Old 12-12-2013, 06:24 AM
Thank you tysindad,
the problem was a fuse. The radio has 2 fuses: 1 identify as radio, the other appears as a/v. In my case this last one was blown.
cheers
post #6 of 6 (permalink) Old 12-13-2013, 07:52 AM
tysinbad's Avatar
Quoted: 6 Post(s)
Glad you got it fixed.
tysinbad is offline
