Sportage (2005) V6 Spark Plug Change Problems - Kia Forum
post #1 of 7 (permalink) Old 04-09-2011, 07:35 PM Thread Starter
I am trying to replace the rear 3 spark plugs on my 2005 Sportage. There is another thread (by BllyBunter) relating to this but I am still having problems. I am having trouble removing the what I think is called the cover (see attached photo of one removed). I have removed 11 fasteners: 5 bolts at the front, 2 nuts at the front (left and right sides), 2 nuts at the rear left (cylindrical section) and 2 bolts at the rear centre/right. BillyBunter's thread mentions that you need to remove 12 fasteners to get this off so there is still one I'm missing. He also refers to the throttle body inlet plenum and the firewall but I'm not sure what these are. If anyone could help me I would be very grateful. It must be that there is a hidden bolt/nut at the rear as it is lifting up slightly at the front but it is solid at the rear. All this to change 3 spark plugs. Rather frustrating.
Thanks in advance.
Fyodor.
Name:	Kia V6 Cover.jpg
Fyodor is offline
post #2 of 7 (permalink) Old 04-09-2011, 09:24 PM Thread Starter
Correction, at the rear left cylindrical section (interface to the throttle body plenum I think), I removed one bolt and one nut. There is still one stud left on there. It looks to me as if the cover should just slide over that stud but it is still stuck solid.
Fyodor is offline
post #3 of 7 (permalink) Old 04-09-2011, 11:56 PM
Quoted: 22 Post(s)
Can you double nut the stud and remove it?
nstoolman1 is offline
post #4 of 7 (permalink) Old 04-10-2011, 12:10 AM Thread Starter
I removed the 2 studs at the front by doubling up the nuts and screwing it out. It doesn't look as if the stud at the rear needs to be removed as it was still in place in the photo that BillyBunter provided. I did try to remove it however just in case but it is very inaccessible and there wasn't enough space to get my wrench in and turn it.
Fyodor is offline
post #5 of 7 (permalink) Old 04-10-2011, 08:12 AM
Premium Member
1fastkia's Avatar
Quoted: 16 Post(s)
Maybe send billy a pm or email and ask him since he has already accomplished this.
Best bet..
1987 Mazda RX-7 GLX
The Old
1fastkia is offline
post #6 of 7 (permalink) Old 05-17-2011, 02:55 PM
Drives: 2005 Sportage EX V6 Auto FWD
Thanks in advance.
Fyodor.
Were you ever able to remove/replace the 3 spark plugs? How?
I'm planning to change mine soon.
norse is offline
post #7 of 7 (permalink) Old 05-23-2011, 08:23 AM
tysinbad's Avatar
Drives: 06 Sportage/2012 Navara V6 TD
Quoted: 6 Post(s)
Another way is to remove the entire upper intake manifold. 5 bolts at the front, 2 nuts at the front.
At ther rear there are two brackets that connect the inlet manifold to the head. Can't remember if they are bolts or nuts on studs. The one on theleft has two (one for the head, one for the manifold). The bracket to the right has 4, two for the head, two for the manifold. The bracket to the right also holds some vacum lines.
What the guys above have explained is to seperate the surge tank halves. The way I have done it does not do this.
Plus connectors etc.
Pain in the ass just to get to 3 spark plugs.
06 V6 EXL Sportage - NGM Stage 1 Sniper Charged
UNICHIP ECU, 2.5" Exhaust, Custom Headers, Modified Intake
tysinbad is offline
