Hey gang!
(2006 Sportage, 6-cyl, 4WD)
I 'changed' my ATF this morning but only a quart drained out even after sitting 15 minutes. The engine was warm. I'm puzzled.
I was debating doing a flush, I have the front bumper cover removed to install LEDs in it and saw the aux trans cooler in front of the condenser so wondered if I could flush with the ports on it instead of the ones in the engine compartment. I've read/heard of folks doing it with either supply or return and I thought return would be better so the coolers would flush out too. I'm pretty sure the return is the hose on the drivers side of the cooler.
I forgot to add that I replaced the drain plug and quart of fluid then started the truck and ran it through all the gears. Then I shut down and removed the plug to drain again but only a few drops came out!
The dipstick read fine, in fact 3/8" higher than the hot mark.
Hi Cobra, it's at 151k, ~60k (miles) on after a rebuild of the tranny.
I have not done a fluid change myself but had one done at 60k and one at 92k (refilled after rebuild).
Rebuild @ 92k after it lost reverse then 1st some time later.
They put a stronger wave spring in for more positive shifting, still not sure that was legit but ???
Looks like your trans was overfilled? Did the drain plug you pulled have a magnet on the inside of the plug? I would pull the plug again to make sure there is nothing clogging the hole, stopping the ATF form coming out.
The hole was/is wide open.
I just don't get how I could drain a quart, pour in a quart, but still have an empty pan. And a overfill reading on the dipstick.
I ran it again for 15-20 seconds, shifted all gears, still a dry pan
Is it normal to only get 1 quart out during a change? I think the oil change place ripped me off pretty good if this is normal.
I'm considering using low pressure air to see if it'll push any fluid to the pan. Although, if this does work then it'd mean something like occluded passages, etc... es no bueno.
I ended up getting in touch with my 22-year-old mechanic friend and she nailed it in less than 5 seconds. She asked "What else is under there that would take just a quart?"...
Transfer case! I was a bit suspicious that the fluid looked so clean when I drained it. That explained it.
I haven't touched an AT since 1994 and it was a 2WD
Thanks for the assist!
I know it! Quite embarrassing but I hope it can help some other hapless fool having a similar 'off-day' situation.
KF information has helped me so much that I haven't needed to post a question since I registered because the search engine here rocks and the questions have already been answered.
I need to dig through my repair and electronic mod pictures and either make some threads or add them to the appropriate existing threads to help others.
