2006 Kia Sportage Timing Belt replacement info
18K views 7 replies 5 participants last post by  ejclide
#1 ·
I am looking for any documentation on changing the timing belt on a 2006 kia Sportage EX 2.7L V6.
I have searched this forum and others to no avail. The Kia tech site is now a pay site.
By chance does anyone have the information saved off and would be willing to share?
#3 ·
I just did it on my 2007 2.7 liter. It was pretty easy, just had an issue with the harmonic balancer being stuck, I used a blow torch and it loosened right um. Also had an issue with the water pump I had was not cast real good and was a tight fit. Here are 2 low res pdfs that may help a little.
#4 · (Edited)
This might help. Sportage service manual.
https://dl.dropboxusercontent.com/u/84804576/WSM.pdf
Timing Belt starts pg 155
I just did this on my 2006 V6 and I can tell you the hardest part was getting the harmonic balancer off. I had to fashion a holder from a puller I bought at Napa parts. Image attached as well. The bolt on there has close to 200lbs torque on it and it's not easy to get off. I luckily had a really large torque wrench that allowed me enough leverage to get the bolt off.
Make sure you have plenty of time and a second vehicle just in case it takes you longer than you thought. I'm pretty mechanical and it took me about 14 hours over 2 days because I kept running into issues. I did the water pump as well and bought a gates kit from Amazon for 150 that had everything you need.
Amazon.com: Gates TCKWP315 Engine Timing Belt Kit with Water Pump: Automotive
The dealer wanted 1000 bucks to do it to replace water pump, timing belt and serpentine belt.
Good luck!!!
