Originally Posted by dnissley
I'm really stumped on this one...
My rear brake lights are always on when the car is on, and pressing on the brakes does nothing to change that. The third brake light works properly though. All turn signals work properly. All lamps work properly. The rear brake lights DO turn off when the car is off.
I switched out the brake light switch, thinking that it might be faulty, but it didn't change anything. Changed the bulbs too, but no change. What the heck's going on here? What should I check next?
hope you sorted your issue out, but just a quick thanks as you post pointed me in the right direction to sorting out mine, it was a bulb it had half blown and was touching the second element in the bulb casusing a short, I had to look closly as you could just see it
