Drives: 1985 Subaru "BumbleBeast", 2000 Kia "KiaStein" and 1969 Mercury Comet
Gallery:
0
2000 Kia Sephia engine Replacement ~ info Needed.
Hi!
My 2000 1.8L 16V Automatic Kia Sephia Needs a New Engine and I Really Need to do that as Fast as Possible; so I Really need your Help to Know Which Kia (or other Brand) engine could be a Direct Replacement for my Kia's T8D engine.
Could the 2006 / 2008 Spectra / Cerato Engines Work in my 2000 Sephia???
is there an 2.0L engine that Fits on my Sephia's engine room???
Nothing is a direct replacment for the T8D.
You would have to have someone fab up a whole new mount system for the engine and tranny mounts.
NO ONE HAS DONE THIS! You would be the first. So there would be no one to help you.
If your thinking about room issues, thats not your problem as there are tons of Mazda RX7s with chevy 302/350 swaps. Thats a V8 fit into a car that has a 1.3L. Point, room is not an issue usually when it comes to swaps. Its ecu's, and the biggey, what would you do for mounting it?
Going from a 1.8L to a 2.0L in my opinion would be a waste. As those spectra 2.0L only have 10 hp over that T8D, and as far as mods, there isn't anything you can get for that 2.0 that you cant get for the 1.8. The 2.0 is heavier, and will most likely be slower than that 1.8 anyways.
08 Kia Sportage
07 Saturn Aura
87 Mazda RX-7
Working on a 07 RX-8
I'll be hunting down engines to replace mine as well. I'll most likely just be doing another 1.8L if I remember correctly the 2002/03 1.8L will work because they are still a T8D. T8D is a T8D. I don't see how they are different at all. Trying to remember everything I've read on them. I believe there's an issue of the intake or throttle body having a bigger opening or something like that on the 02/03's verses the 2nd Gen Sephia.
Gallery:
0
Somehow is Sad for me to Change the Kia's engine... My Yellow Subaru (On my Avatar) is Over 25 Years old and over 400,000 Miles and I've only Changed Both Headgaskets and a Waterpump; Also my '69 Mercury has Still "Standard" its Engine...
OK, I Just Found a '03 Spectra engine in Good Condition, with 80,000 Miles and at an affordable Price (Without Both Manyfolds and EFi Stuff) I Think I'll buy it...
Gallery:
0
Originally Posted by 1fastkia
THe manifold are the difference, you cannot use yours on an 03 motor. Port sizes are different. And your efi stuff is going to be different.
Very VeryRespectfully, let me Tell you This:
Fortunately You was Wrong!!!
Last Weekend I Went to Hunt for a New Engine for my Kia Sephia (my Kia Sephia was Built in Late 1999) and I Found a Donor Car which was a Late 2003 Kia Spectra.
I Only Purchased the Block along with the Head Assembled as it came from Factory, in other Words: my Wallet wasn't enough big to purchase the Complete engine from the Junk Yard, so they Taken off This Parts from the Engine: (Parts Removed in order to Lower the Price)
[♪]intake Manyfold complete.
[♪]Exhaust manyfold Complete.
[♪]Flywheel.
[♪]Front main Pulley.
[♪]Engine Mounts, except the one in front of the Timin' Belt Cover. (The old one Damaged)
[♪]All the E.F.i. Stuff, including ignition Coils, etc...
My Sephia still Ran with its original engine (Blowin' a Cloud of Smoke) and I Went to Purchase the New engine Driving it; so I Take a Picture of the New (to me) Engine on the Trunk:
I've Worked this whole Week during Night time to do the Swap...
[♪]First Night I Removed the Sephia's Old & Worn T8D Engine.
[♪]Then with Both engines Lyin' on the Floor, I Swapped intake Manyfolds.*
[♪]Then the Other Parts.
[♪]Brand New "Denso" U-Groove Sparkplugs.
[♪]Brand New "Motul" SAE 15W~40 Oil & Luber-Finer Filter.
[♪]Placed the New (to me) Spectra's T8D Engine on the Sephia's Bay.
[♪]New "ShellZone" Coolant.
[♪]...and That's it!
The Spectra Engine Fired Right on the First Key Turn and Purred like a Kitten!!! Just half hour ago...
*So, 1fastkia was Right about the Port Differences: the Port Shapes are Different, let me Explain: The Sephia'a T8D engine Ports are Oval while the Spectras T8D Engine's Ports are Squarier and bigger: But the intake Manyfold of the Sephia Cover Perfectly the ports on the Spectra Engine: I've Just "Been There, Done That" So I Used my Sephia's Engine Stuff on the Spectra engine and Worked 100% Well!
Now I'm So Tired...
I'll Have enough time to Test the Sephia this comin' Holy Week, in a Very Long Travel, also I'll Post More pictures & Explanation.
Kind Regards.
JesZeK.
Reason: Add Image
