#1
Mar 2, 2011
(Edited)
Hello Members,
I would like to ask that if you are going to post about your CEL (check engine light) comming on for you, that BEFORE you post, please get the car scanned (the ECU, your cars computer) and get the code/s that are making the CEL come on.
This will really help in everyone that is here to help, or can help, know what is going on with your car.
You can get your car scanned at Autozone, Advanced auto parts, and some other parts stores. Usually at the bigger name parts stores it is free, some will offer loaners, where you put a small deposit on the scanner, & you get it all back, upon bringing it back.
Or at any shop or dealer. But these there is usually a small fee of between 20-40, from what I have seen.
You could also buy a generic scanner (just for codes, nothing else) for 40-100 dollars on ebay or other online sources or even parts stores.
But to the point, its hard to help with a CEL, without the codes, otherwise its most likely a guess, going by what is happening with the car....
Thanks from Kia-Forums....
See less
See more
#2
Mar 18, 2013
2000 Sephia Codes
P0101 Mass or Volume Air Flow Circuit Range / Performance
P0102 Mass or Volume Air Flow Circuit Low Input
P0103 Mass or Volume Air Flow Circuit High Input
P0111 Intake Air Temperature Sensor 1 Circuit Range / Performance
P0112 Intake Air Temperature Sensor 1 Circuit Low Input
P0113 Intake Air Temperature Sensor 1 Circuit High Input
P0116 Engine Coolant Temperature Circuit Range / Performance
P0117 Engine Coolant Temperature Circuit Low Input
P0118 Engine Coolant Temperature Circuit High Input
P0122 Throttle/Pedal Position Sensor/Switch 'A' Circuit Low Input
P0123 Throttle/Pedal Position Sensor/Switch 'A' Circuit High Input
P0125 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0126 Insufficient Coolant Temperature for Closed Loop Fuel Control
P0128 Coolant Thermostat (Coolant Temperature below Thermostat Regulating Temperature)
P0130 O2 Sensor Circuit(Bank 1 / Sensor 1)
P0131 HO2S Circuit Low Voltage (Bank 1 / Sensor 1)
P0132 O2 Sensor Circuit High Voltage(Bank 1 / Sensor 1)
P0133 O2 Sensor Circuit Slow Response (Bank 1 / Sensor 1)
P0134 O2 Sensor Circuit No Activity Detected (Bank 1 Sensor 1)
P0135 O2 Sensor Heater Circuit(Bank 1 / Sensor 1)
P0136 O2 Sensor Circuit(Bank 1 / Sensor 2)
P0137 O2 Sensor Circuit Low Voltage (Bank 1 / Sensor 2)
P0138 O2 Sensor Circuit High Voltage (Bank 1 / Sensor 2)
P0139 O2 Sensor Circuit Slow Response(Bank 1 / Sensor 2)
P0140 O2 Sensor Circuit No Activity Detected (Bank 1 / Sensor 2)
P0141 O2 Sensor Heater Circuit(Bank 1 / Sensor 2)
P0171 System too Lean (Bank 1)
P0172 System too Rich (Bank 1)
P0201 Injector Circuit/Open-Cylinder 1
P0202 Injector Circuit/Open-Cylinder 2
P0203 Injector Circuit/Open-Cylinder 3
P0204 Injector Circuit/Open-Cylinder 4
P0261 Cylinder 1 Injector Circuit Low
P0262 Cylinder 1 Injector Circuit High
P0264 Cylinder 2 Injector Circuit Low
P0265 Cylinder 2 Injector Circuit High
P0267 Cylinder 3 Injector Circuit Low
P0268 Cylinder 3 Injector Circuit High
P0270 Cylinder 4 Injector Circuit Low
P0271 Cylinder 4 Injector Circuit High
P0300 Random/Multiple Cylinder Misfire Detected
P0301 Cylinder 1-Misfire Detected
P0302 Cylinder 2-Misfire Detected
P0303 Cylinder 3-Misfire Detected
P0304 Cylinder 4-Misfire Detected
P0326 Knock Sensor 1 Circuit Range/Performance (Bank 1 or Single Sensor)
P0335 Crankshaft Position Sensor A Circuit Range/Performance
P0336 Crankshaft Position Sensor A Circuit Range/Performance
P0342 Camshaft Position Sensor A Circuit Low Input (Bank 1)
P0343 Camshaft Position Sensor A Circuit High Input (Bank 1)
P0422 Main Catalyst System Efficiency below (Bank 1)
P0441 Evaporative Emission System Incorrect Purge Flow
P0442 Evaporative Emission System-Leak Detected (Small Leak)
P0455 Evaporative Emission System-Leak Detected (Large Leak)
P0460 Fuel Level Sensor Circuit
P0501 Vehicle Speed Sensor A Range/Performance
P0506 Idle Air Control System-RPM Lower than Expected
P0507 Idle Air Control System-RPM Higher than Expected
P0561 System Voltage Unstable
P0562 System Voltage Low
P0563 System Voltage High
P0601 Internal Control Module Memory Check Sum Error
P0604 Internal Control Module Random Access Memory (RAM) Error
P1115 Engine Coolant Temperature (ECT) Sensor Signal From ECU to TCU
P1307 Idle Charge Actuator Signal Low of Coil #2
P1308 Acceleration Sensor - Low Input
P1309 Acceleration Sensor - High Input
P1386 Kncok Sensor Circuit Malfunction
P1446 DMTL Motor Circuit Malfunction
P1447 Evaporative Leak Detection Pump Circuit Malfunction
P1448 Evaporative Leak Detection Pump Circuit Malfunction
P1458 A/C Compressor Input Signal Malfunction
P1505 Idle Speed Control Actuator Circuit 1-Low
P1506 Idle Speed Control Actuator Circuit 1-High
P1507 Idle Speed Control Actuator Circuit 2-Low
P1508 Idle Speed Control Actuator Circuit 2-High
P1586 M/T-A/T Encoding Signal Malfunction
P1611 Malfunction Indicator Lamp (MIL) Request Circuit Low
P1614 Malfunction Indicator Lamp (MIL) Request Circuit High
P1624 TCM MIL On Request Signal
P1673 Cooling Fan Circuit Malfunction
P1693 Malfunction Indicator Lamp (MIL) Control Circuit
