HELP! 2000 Sephia Cylinder #1 Misfire
8K views 5 replies 4 participants last post by  ron1004
#1 · (Edited)
Hello everyone I am new here.
I have a 2000 Kia Sehia and it has a BLINKING check engine light of P0301 "Cylinder #1 Misfire".
I have checked the compression across all cylinders and they are all right at 150-160 psi.
The car has 92,000 miles on it.
I have been unable to find a diagram to see what the cylinder order is. When looking down at the engine, does cylinder #1 start on the timing belt side or the battery/transmission side?
I'm not very familiar with the distributor less system and that makes it harder to just swap out wires to test if they are bad. All 4 spark plugs looked fine.
What should my next tests be? I would like to swap 2 of the fuel injectors too but I need to know which cylinder #1 is first, thanks for the help :)
Also: I have a junk yard locally that is pull your own parts and I would like to pick up another coil pack, plug wires and fuel injector, what other years and makes of Kia's share those same parts?
See less See more
#2 ·
Its most likely a bad wire for cylinder 1. It goes Wire to cylinder 1 then Coil over 2 wire to 3 coil over 4.
1. Disconnect from coil and spark plugs.
2. Check for breaks in insulation.
3. Check inside high-tension lead connectors for corrosion or carbon deposits.
4. Connect high-tension lead to an ohmmeter and check resistance.
Resistance: 16kΩ per 3.28 feet (1 m)
5. Replace if defective.
#4 ·
I'm having the same problem with my Kia Sephia, I've tried changing the plug wires and the fuel filter so far and that hasn't done anything. what should i try next???
Welcome to the forum.
When last did you change the spark plugs, what type, and what gap ?
A good sequence would be change the plugs (correct type and gap - NGK 0.030"), then plug wires, coils, .......... a choked fuel filter would cause multi cylinder misfire.
